PT425
/ PT425 #21
I find the same problem with the exhaust pointing down. At least for the creation of dust storms. Pointing it straight back or angled up would work much better. Instead of modifing the current muffler maybe it might be better just to replace it.
/ PT425 #22
/ PT425 #23
I had the same problem with the exhaust... I was wondering where all the brown streaks in the grass were coming from....
I took a 90 degree cast iron 2" (?) elbow and sort of screwed it in place to direct the exhaust backwards, which has stopped that problem.
I really don't like the exhaust arrangement on the PT. The "muffler" just doesn't work very well. Some others on this forum have replaced it with a supertrap, although that is an engineering challenge, since it exits in a 360 degree arc, which can add heat to the engine compartment or burn your tire.
supertrap muffler thread
/ PT425 #24
/ PT425 #25
First -- my PT came with a heat deflector mounted on the tub just below the exhaust outlet. Don't your units have it?
And an appropiate update:
The SuperTrap is still working great. It's canted somewhat out and to the rear from my experimenting with the vaporlock solutions (moving the entire "fuel system" to the right side of the machine fixed that problem acceptably -- it hasn't died from VL since, but after working hard and long, then shutting down, upon restart I can hear the electric pump has vapor in it, but the PT still starts and runs).
I have added to my 'round tuit' list rewelding the SuperTrap back to the vertical but that's not high on the list as it's working fine now. I used the stock deflector plate behind the Supertrap to help prevent it from being hit when I'm backing around in heavy brush.
If I had a decibal meter it'd be easy to get readings "before" and "after" since all of the SuperTrap comes off with one nut, except the part that's welded to the PT muffler.
I have a Fluke multimeter (88 comes to mind but I could be way off as memorizing numbers is not my strong suit). If anybody has an idea on how I can measure decibals with it I'm willing to do it in order to get some definite numbers.
Or if someone has a meter that adapts to a Fluke, or a meter by itself, and wants to lend it to me I promise to return it.
Phil
/ PT425 #26
Phil
/ PT425 #27
</font><font color="blue" class="small">(
I really don't like the exhaust arrangement on the PT. The "muffler" just doesn't work very well. Some others on this forum have replaced it with a supertrap, although that is an engineering challenge, since it exits in a 360 degree arc, which can add heat to the engine compartment or burn your tire.)</font>
I think PowerTrac is just trying to cope with finding an engine that fits the specs. I think the exhaust outlet on all of these engines exits at roughly the same place which means PT has to turn the exhaust around. But I would think that the 90" bends in their exhaust pipe isn't going to benefit engine longevity or power production. The whole setup is probably pretty restrictive. What we need here is a decent set of headers! /forums/images/graemlins/grin.gif
/ PT425 #28
/ PT425 #29
I think PowerTrac is just trying to cope with finding an engine that fits the specs. )</font>
Too bad they don't fit a really quiet Honda in there... all you'd hear then is the purrrrrrrrrrrrrrrrr and the PT whine.
/ PT425 #30
/ PT425
Phils........No my doesn't have a heat deflector, just 1 1/4 square exhaust pipe pointing down.
Toolz.......I agree a good header system would rock.
I got around the exhaust direction by welding another short piece of 1 1/4 box steel to the exhaust pipe exiting out to the rear of the machine.
/ PT425
/ PT425 #33
Tricker,
Nice mod, I will be doing the same soon. Did you weld the piece directly onto the stock exhaust can?
Also, how's that thermo coupler problem? Is the tractor back in action?
Tim
/ PT425 #34
Tricker,
Tim
/ PT425 #35
<font color="blue"> Too bad they don't fit a really quiet Honda in there... all you'd hear then is the purrrrrrrrrrrrrrrrr and the PT whine.
</font>
<font color="red"> I have a Hustler FasTrac with a 20hp Honda engine. It is a sweet runner, but cost $500 more than the same FasTrac with a 20hp Kohler!! How many PT buyers would 'whine' about paying over $500 more for a little extra quiet?? </font> /forums/images/graemlins/confused.gif
/ PT425 #36
</font>
/ PT425
</font><font color="blue" class="small">( Tricker,
Tim )</font>
Tim, I welded directly to the factory exhaust at a 90 degree angle and yes, the thermo coupler fixed the problem. PT is running like a top /forums/images/graemlins/smile.gif
/ PT425
Tim )</font>
2019 TAKEUCHI TL12V2 SKID STEER (A64279)
2019 TAKEUCHI...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2010 INTERNATIONAL PROSTAR PREMIUM ROAD TRACTOR (A63291)
2010 INTERNATIONAL...
