PT422 Stuck in mud
/ PT422 Stuck in mud #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
Well, I got really stuck today. There was a heavy rain of about an inch. I was checking out the creek and noticed that the old beaver dam was making the creek back up and flow where I did not want it to go. When the water had gone down some, I took the 422 and 4 in 1 bucket down and tried to break up the dam. This did not work too well and I felt that I was in danger of getting stuck. I came back later with the minihoe mounted. This is the best attachment to have if you anticipate getting stuck (at least it had always worked before). I took a few bites out of the dam and a little water started to flow. I tried to back up and all wheels started to spin. No problem, I'll just use the minihoe to push the 422 backwards. This helped a little, but the minihoe bucket sunk into the mud and other mud built up behind the back wheels. After working with the minihoe for about 15 minutes, I decided to get out the come along. I connected one of my tow straps to a nearby tree and the other to the hitch. I then tried tightening the come along as much as possible and then got in and tried to back out. With the help of the minihoe I moved a little. I got out, tightened the come along, tried again, and was able to move a few more inches. I was getting pretty close to the tree with the strap, and I did not want to be stuck against it. I then moved the tow straps to a more distant tree, one where the 422 would be pulled sideways. I also put some logs behind the front wheels, there were deep ruts in there by now. I tightened the come along, I then put a 2 foot long 6X6 under the strap near the back of the power track. This way when you tighten the strap the 422 is lifted up. This worked and I was able to get out on the next come along tightening. Here are my recomendations.
1. Stay out of the swamp (you've been stuck there before, so why keep trying).
2. Raise the strap at the tree about six feet off of the ground. This way some of the pull is up. Pulling straight back will not work. Don't pull the tree over on you though.
3. Put a board or log under the strap near the 422 after the initial tightening.
4. Get a friend to tighten the come along while you drive. This would have been a big help, but my nearest neighbor did not answer the telephone and my wife has a weak back.
5. Make the strap a long as possible so when you move back a little, there is still tension. With a short strap to a nearby tree even a little movement removes all of the tension.
6. Try not to spin the wheels, this just digs you deeper.
7. Hose the tractor off because it is really muddy by now.
8. Take some pictures after the tractor is out, because it's raining and you want to get the tractor out before it washes down stream.
9. Buy a come along and at least two 30 foot tow straps.
10. I wonder if a really strong coiled spring in the line would allow for tension to remain over a longer backing distance. Of course the energy stored is this could be fatal if something breaks loose.
I hope this helps the next stuckee.
Bob Rip
/ PT422 Stuck in mud #2
You did good! /forums/images/graemlins/smile.gif
These things are hard to stick, even with turfs. I've had the PT-425 in where I instantly bogged down my Tacoma 4x4. So far, no problems. /forums/images/graemlins/laugh.gif
/ PT422 Stuck in mud #3
Sounds like great fun! I sometimes get stuck just to have an excuse to practice getting out. I'm usually sliding sideways into a tree on a 20 degree slope when it happens though. One question I have is when I hook a chain or tow strap to the tractor and pull with my truck I always leave the tractor running at a low idle, is this necessary or is it better to have it turned off ? I think it may be easier on the hydraulics to have it running.
db
/ PT422 Stuck in mud #5
Do you have the turf tires or the ag tires? If you have the turf tires do you think ag tires would be any better?
/ PT422 Stuck in mud #6
Bobrip--you forgot step number 2- if fellow PT owner lives 5 min. away-call so he "learn" from your experience.As you know I don't post here, but do read often and print out many helpful hints the users mention.I put them in my PT file for future ref.in case needed.I do have the 425 which has served me well for the 15 months I have owned it-Bob--don't get stuck again just so "Butch" can come to assist, but if you do just give a call-extra seat time on my P/T is just an excuse to "play"---Joeym
/ PT422 Stuck in mud #7
We should forward this thread to this guy
/ PT422 Stuck in mud #8
</font><font color="blue" class="small">( my wife has a weak back.)</font>
I think this is the problem, if you get that replaced with one of those heavy duty wives, next time you go to the swamp you can be pulled out no problem.
/ PT422 Stuck in mud #10
I agree, they are really hard to get stuck. Note #1 on BobRip's list. He thought he was buying the Power-trac six wheel amphib, and didn't realize until he was in the swamp that it was really just a four wheel drive tractor. I've tried to convince him that the mini-hoe is not the best tool to take care of the beaver ****, dynamite works much better. He mumbles something about scaring the cats.
/ PT422 Stuck in mud #11
I don't know what kind of fellow Power-trac owners live near you. BobRip would never call any of us near him because we would just drink his bear and laugh at him trying to get his tractor out of the swamp.
/ PT422 Stuck in mud #12
<font color="blue"> BobRip would never call any of us near him because we would just drink his bear and laugh at him trying to get his tractor out of the swamp. </font>
I guess it could just be the spelling, but I got a really disgusting mind picture when I read that. /forums/images/graemlins/crazy.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif
I have the bar (ag )tires. The between bars area is so filled with mud that I don't think there would be much difference. Just an opinion.
Bob Rip
I did not use up all of my swamp. Feel free to bring your PT over and get it stuck. We could have a contest!!
Prizes for:
Highest mud up the canopy.
Fastest getting unstuck with the tools you carry on board.
Most mud weight gained.
Most damage getting unstuck.
Some how it's not so funny when the creek is rising and you are still stuck. Well actually the creek was not rising but it was starting to rain again
I usually leave the engine running because it easier to get an engine running if its already running. I used to own a Rambler and the starter did not work very well if the engine was hot.
Take care, but not all of it.
Bob Rip
/forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
Six wheels, 10 wheels, tracks, I think in the swamp nothing would have made it.
Not everybody stocks 1000 lbs of explosives like Clint
Bob Rip
/ PT422 Stuck in mud #16
Have you considered the 5 ton winch that PT has or another brand winch, electric or hydraulic. Just might come in handy if you are going to play in the swamp. /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
I have seriously considered the PT winch. It is now down to two tons. I think somebody pulled their PT in two with the 5 ton so PT down sized it. The schedule is to purchase it next year. Actually I do have a small electric winch, I just like the challenge of the comealong.
Bob Rip
2025 Poly Fuel Tank with Electric Pump (A61568)
2025 Poly Fuel...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
2016 Chevrolet Express 2500 Cargo Van (A61568)
2016 Chevrolet...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
