PT180 Oil Cooler
/ PT180 Oil Cooler #1
DML
KY
PT180/56 FORD
I am planning on putting a hydraulic oil cooler on my 180. Given that the 180 is supposedly built not to need one, I am leaning toward one without a fan, maybe a motorcycle oil cooler. Any comments or suggestions? Also, I was wondering if somebody could post or send me a picture of how their oil cooler is set up from under the hood, maybe somebody with a 422?
/ PT180 Oil Cooler #2
I wouldn't mind taking and posting photos, but I think you would be making a mistake by not installing a fan. If it's placed in the top of the motor cover, as it is on most, without a fan you'll just be HEATING your oil from rising engine heat. IMHO you'd be better off without the cooler than mounting it without a fan.
But if you still want photos, PM me and I'll try and help.
Phil
/ PT180 Oil Cooler
I have taken into some consideration that if mounted on top, a cooler without a fan would soak up heat from the engine. I was actually thinking of a motorcycle oil cooler that is designed to mount on the front down tubes of a motorcycle, and kind of thinking of mounting it somewhere off the side or back of the tractor so that the coolers actually stick up kind of like antenae. I thought it would catch more of a breeze there. My current method of cooling the oil involves a spray bottle filled with water that I mist the oil tank with every now and then and let it blow off some steam!
/ PT180 Oil Cooler #4
I have a 422. I'll go out and take a pict of it.
Could you get a radiator w/electric fan from a wrecking yard and put that on? I think somebody here said that
/ PT180 Oil Cooler #6
I would second Phils rec for a fan. These tractors move far too slowly to achieve sufficient airflow through a conventionally designed oil cooler. The downtube and fork mounted coolers on motorcycles take advantage of speeds of 25 mph or above to effectively cool the oil. Unless your PT is a racer, those speeds are not gonna happen.
For effective cooling at LOW SPEEDS, w/o a fan, you might consider a different technology, such as aluminum wire wound coolers {HERE} . The ones made by SHE are very efficient, and are designed to replace much larger tube coolers and to be used at low air flows.
With that said, I still think a fanned cooler is the way to go for your PT. You can get a fused Perma-Cool Maxi Cool Junior {HERE} and it will measure around 3x10x12, a pretty darn small footprint. The 10 blade fan will give you 950 cfm airflow. I believe you need that, especially on hot days when that engine heat is rising.
/ PT180 Oil Cooler #7
Seems like a motorcycle cooler would be too low of capacity. If I remember right the oil flow is 8 gpm? Surplus Center has hydraulic coolers $35. You could also use a trans cooler for a truck or car. They are about $35-40 new from an auto parts store. I also would recommend a fan.
/ PT180 Oil Cooler #8
Hmmm... I have a couple questions.
1. What's the block/knob inline with the hose in the bottom left part of the picture?
2. Does anyone know why they use the parallel pipe design for the flow?
Most automotive radiators "S" the piping back and forth thru the fins don't they? I guess their design would slow down the flow, redirecting the 8 GPM into 4 2 GPM streams.
The only problem then is that the 2 GPM is only being cooled for the width of the radiator vs the 8 GPM flow which could be cooled over the 6 to 8 passes through the radiator with an "S" design.
/ PT180 Oil Cooler #9
That black knob is the heat sensor that cuts the fan on.
/ PT180 Oil Cooler #10
A car radiator is rated at 15 psi typically. I don't know what the pressure is at the oil cooler, but the tubes look pretty heavy duty. I would think that the back pressure created by the car radiator would build up much too high a pressure in my opinion.
Have you measured the temperature? What makes you think it is too high?
I wonder if just adding a fan on the side of the back cover would remove a lot of heat? This would sure be easy to do and keep you out of the high pressure hydraulic lines. The engine heat would not add nearly as much heat to the hydraulics and most of the heat generated in the system is from the engine. At best the engine is about 30% efficient, meaning that 70% of the energy in the fuel goes out of the engine as heat. Thirty percent is probably a high figure.
Bob Rip
/ PT180 Oil Cooler
Thanks for the responses. I think I will go with a fan type. The perma cool sounds great, but from what I understand they run around$150 compared to the Surplus Center's $35-40. But then you get what you pay for. A little more thinking, and then deciding if I should try to install myself....
/ PT180 Oil Cooler #12
Just use a fan. Try a junk yard and test one. Should be pretty cheap.
Bob Rip
/ PT180 Oil Cooler #13
As my grandpa told me at his knee (more years ago than I care to remember) <font color="brown">"Buy right and cry only once." </font>
A good cooler will do all that you are asking, and more. With a cheapie, you'll always be looking over your shoulder waitin' for the connections to burst or the fan to fail. That's my 2 cents from the car racing perspective, where failures on the track cost dearly.
2014 MACK PINNACLE DAYCAB (A59914)
2014 MACK PINNACLE...
2018 KAUFMAN 44 FT T/A  CAR CARRIER TRAILER (A59914)
2018 KAUFMAN 44 FT...
2021 Felling FT-45-2LP 29ft. 26 Ton Tag Trailer (A64194)
2021 Felling...
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2022 EZ-GO ELITE...
