PT Safety Modifications
/ PT Safety Modifications
KentT said:
Bob, do you do much work in the woods? I was just wondering, because I'd likely rip off a mirror mounted where your new ones are, banging it on trees, etc. I've actually punched the right headlight hard enough with a tree limb to knock the bulb loose and back into the rubber housing -- and the headlights are INSIDE the ROPS...
Kent, you got me thinking. I wonder if mouting the mirror inside the ROP pole would help. It would block a little forward vision, but might be alright. I will try it. Should only take a few minutes to change. Thanks for getting me thinking. That's what we do here isn't it.
/ PT Safety Modifications #12
BobRip said:
Kent, yes I do go through the woods a lot. Nine of my 10 acres is in woods. I will try to be careful. I really only intended to use the mirror on the road since you have a good view behind normally. I have the lights mounted under the ROPS and so far none have been destroyed. I did have to replace the flashing light on the back top of the ROPS once. That's in a sucide postion. I probably should have shopped around for a cheaper mirror and may regret spending $45 on this one.
You could do something like this
Pegasus - Wink Jr. Mirror: 3 Panel - 21 inches Long
Or
Legends Racing 975000X047 Rear View Mirror@ RACEPARTSUSA.COM Oval Track Racing Parts and Accessories
Or if you decide to put spinners on your 425 and maybe lower it you could go this route...
Dual 4.2" LCD/TFT Rear View Mirror/Reverse Parking System w/Camera
I tried putting it inside the pole and I go a good view of my left shoulder. I put it back and adjusted the backet so that the mirror can fold backwards quite a bit if hit by something. This should help. You know it's inside the tire outer dimensions, so it might be a little difficult to hit something really solid. Overhanging branches may hit it of course. I will drive through the woods tomorrow and see if I can expose to hazards, hopefully without damaging it.
/ PT Safety Modifications #14
I plan on getting some kind of mirror for on the road but I'm afraid a nice one like that would last me about 2 minutes mowing under brush in the woods . If the PT wasn't all steel it would be in the scrap heap by now. How about a mirror attached to some kind of large spring clamp so you could just use it when on the road. As for as backing up, I would rather just turn around and look directly where I am going.
It can now fold back if it hits some thing.
/ PT Safety Modifications #16
To all. Why block your view? Why not put a large mirror under the ROPS, center, or one in each corner It has worked for cars for a long time now. That's where mine is. Mine is curved, good for seeing if anyone is behind the machine. For backing, I turn my head and look.
J_J how about a picture. I have a center mirror and I need to drop it a little because I have a light handing down from underneath the back of the ROPS.
I am reasonably happy with the new mirror I have added. Ten minutes of use and it has not broken yet. And actually it has been in the garage all night and not broken yet. :D
/ PT Safety Modifications #18
I have one of those Pegasus type mirrors on my golf cart (See Woodlandsfarm post #12) and it works great there. It's tight to the top so no vision obstruction and mounts to the vertical canopy struts. I don't know if they make one that would fit exactly between the ROPS supports but I doubt if that would pose much of a problem with anyone in this group.
/ PT Safety Modifications #19
I guess I'm cheap -- I used one of the cheap soft plastic trailer-towing mirrors that you strap on to existing mirrors. I mounted it up under the center of the ROPS, just behind the cross-bar. Though this picture doesn't show how it's mounted, it does show its location:
http://www.simpletractors.com/subsite/2_IMG_0099.JPG
It doesn't really obstruct my view since it's higher than my line of sight, and gives a reasonably good view of what's behind me when I'm tramming in a straight line -- which isn't very often, or very far.
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
Kuhn FC400RG (A60462)
2016 Case CX55B Midi Excavator (A60352)
2016 Case CX55B...
2016 Chevrolet Trax AWD SUV (A59231)
2016 Chevrolet...
2019 CATERPILLAR 5K FORKLIFT GP25N (A60736)
2019 CATERPILLAR...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
