PT Rises from the Ashes
/ PT Rises from the Ashes #1
Sedgewood
Platinum Member
Columbia Co, Eastern NY
PT-1845
<font color="red">Success! - and not a moment too soon - its a jungle out there. (see attachment) </font>
Here are my notes from Sunday and Monday. I'll have more details and pictures of some of the long road leading to this (so far) successful rebuild from the fire as soon as I can get organized a bit. My focus has been on the tractor the last few days as you might imagine. /forums/images/graemlins/tongue.gif
Sunday 9/07/03 Initial startup. Decided to forego the usual commissioning procedure of filling the motor and pump cases. Since none of them were actually removed I thought I could presume they still contain enough old hydraulic fluid to lube bearings etc during startup. Hope I was right! I did prefill the new hydraulic filter and the line from the filter to the charge pump. And I put the tractor up on blocks so I could initially gently run the wheel motors unloaded. Then I did the usual after-filter-change air purge. That complete I turned the ignition on, cranked, and the engine started instantly. I let it idle a few minutes while checking for leaks, etc. Then I slowly ran the wheel motors backwards and forwards for a few minutes. Then cycles the cylinders several times. Then let the tractor down off the blocks and slowly drove the 500 feet or so to the mower, hooked it up, and ran it slowly for a few minutes. Everything worked fine except the starter and the fan which I inadvertantly hooked up backwards. No leaks. When I had the starter solenoid replaced, the mechanic could not determine the proper replacement and took his best guess at one he thought would have the correct throw. He missed a bit. The solenoid doesn't make electrical contact to start the starter rotating until a tad beyond contact with the flywheel so if the solenoid doesn't throw the pinion right between the teeth of the flywheel, no go.
Monday 9/08/03 I tried shimming the starter out a bit with some washers and it works fine, but I don't think it is stable enough for a permanent fix. I mowed for a while and all seems ok so far except for a flat tire on the mower :) And when I went to fix that the tractor would not start - push the button - nothing. I must have a screw loose.
Off to do a bit of diagnostics,
Sedgewood
/ PT Rises from the Ashes #3
Great news, this has been a long road for you. Appreciate your keeping us up to date, not fun but you probably will be the best machanic around on the PT machines.
PJ
/ PT Rises from the Ashes #4
Sedgewood -
We all remain amazed at your intestinal fortitude in your ordeal, and we are cheering you on as you proceed with your (successful!) rebuild. I for one am considering whether I should just design a halon system for within the engine bay!
Congratulations, and thanks so much for keeping us all in the loop. Completely fascinating reading.
Cheers!
Rob /forums/images/graemlins/smile.gif
/ PT Rises from the Ashes #5
John,
Hans may win the PT test pilot award, but you've got the PT rebuild award. Great job on a master jigsaw puzzle.
Duane
/ PT Rises from the Ashes #6
Great News! Heck, you may want to start manufacturing these things now. /forums/images/graemlins/smile.gif
/ PT Rises from the Ashes #7
Congratulations on getting everything back together!
I noticed in looking at your parts purchases that you purchased hydraulic fluid <font color="red">(25 gal Kubota AW ISO VG 46 hydraulic oil from Columbia Tractor ) </font> rather than motor oil for the hydrualic system. What caused you to change?
/ PT Rises from the Ashes #8
Congrats! Great news /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif /forums/images/graemlins/cool.gif. I know how satisfying it is when you put it back together & it works! I've been monkeying with my old leaf blower (a much smaller project than yours). Can't tell you how happy I was (and wifey) when I got it running in time for the fall apple & leaf season.
<font color="red"> And when I went to fix that the tractor would not start - push the button - nothing. I must have a screw loose.
</font>
My newfound intimacy with this beast sure made diagnosing this little problem easy! Since the 14/12 cable was burned back a bit, I built a new junction box (see attachment) and mounted it under the fuel tank, where the now shorter cable would reach it and where the box is much handier to access too (PT are you following this?). In addition to the terminal strip I put the fuses in there too. And added a ground bar from an old electrical panel. Then when I rewired I used SJ 14/4 and 14/2 cable for everything and brought all the grounds to the ground bar.
Fortunately when I needed one additional conductor up at the dash, I ran a 14/4 up through the tunnel to give me some spares. It turns out my starter problem is a break in continuity INSIDE the 14/12 cable! That must be a manufacturing defect that finally separated from all my pulling and tugging of hydraulic hoses through the tunnel - it's pretty full when they are all in place.
Gotta go play PT,
Sedgewood
smartguyz: <font color="green"> I for one am considering whether I should just design a halon system for within the engine bay! </font>
Having a fire extinguisher less than 500 feet away might have saved me some grief. That said, I still have to get one and find a place to mount it.
Better put that on my todo list,
Sedgewood
Bob999: <font color="red">Congratulations on getting everything back together! </font>
Thanks MossRoad, pajaube, smartguyz, duane, marrt, Bob999. And a special thanks to Charlie for his ongoing support and assistance. It's been a long haul and I've learned a lot, some of which I hope I can share. I've fallen a bit behind on documenting what I've done at my web site. I want to add a better wiring diagram, some better hydraulic circuit diagrams, and some more pictures, etc. There should be enough similarities between the red and green machines that the greenies, who vastly outnumber the reds, can get some benefit from this too. I know I had a hard time making sense of PT's wiring and plumbing diagrams and maybe I can improve on them enough to be helpful.
<font color="red"> I noticed in looking at your parts purchases that you purchased hydraulic fluid (25 gal Kubota AW ISO VG 46 hydraulic oil from Columbia Tractor ) rather than motor oil for the hydrualic system. What caused you to change? </font>
Bob's been paying attention! That was the toughest decision of the project, mainly because I know so little about hydraulics. Sauer Danfoss, maker of the variable volume pump, has some excellent technical info on their web site, in particular Hydraulic Fluids and Lubricants Applications Technical Information and Design Guidelines for Hydraulic Fluid Cleanliness Applications Technical Information, two rather large PDF downloads. I printed these out and studied them until I thought I had some idea what to look for. They recommend many fluids, including motor oil. Other than basic lubrication qualities, the main thing seems to be to keep viscosity within certain limits and ISO VG 46 seems to be the best compromise for my climate, provided it has a high enough viscosity index. Kubota's fluid was what Columbia Tractor had in stock at the time and apparently they sell a lot of it. I never did find any specs on the Kubota fluid's viscosity index though the label says "All Weather" so I assumed it does and took a bit of a gamble that what "everybody is using" should be ok. /forums/images/graemlins/tongue.gif
Does anyone know why PT uses motor oil (there's nothing wrong with using motor oil)? And then muddies the water with conflicting "Use only 10W30" and "Use only 10W40" documentation and stickers? /forums/images/graemlins/confused.gif
Sedgewood
/ PT Rises from the Ashes #13
</font><font color="blue" class="small">(
Sedgewood )</font>
Sedgewood, I spoke to Terry about this some when I purchased my PT425 and found the conflicting information. According to Terry, the 10W-30 is a typo. They use Mobil 10W-40. Terry said that they used to use hydraulic fluid, but after some issues arose where different people from different areas of the country found that they couldn't find the exact hydraulic fluid brand and viscosity PT was using - PT gave this some thought and decided that since motor oil was both perfectly acceptable to use in the PT, and was pretty much universally available across the USA, they would make the switch. He said this has eliminated the issues they were having with not being able to locate the correct hydraulic fluid for all users.
Great to see you back in business! If you have a chance, we'd love action shots! (I also relish any 'improvement' shots, like your junction box shot! Thanks so much!)
Sincerely,
Rob /forums/images/graemlins/grin.gif
/ PT Rises from the Ashes #14
John,
I've read every page of your web site. I'm afraid Mossroad may have some catching up to do. /forums/images/graemlins/smile.gif. The information you are documenting will be very helpful for all PT owners.
Anyway, one of your links took me to a site (hydraulicsupermarket.com) that has a newsletter on hydraulics. One of the items in the news letter talked about the difference between hydraulic fluid and motor oil. Besides viscosity differences, one other major difference is the ability to separate water out of solution. Apparently, high quality hydraulic fluid has a number of additives that separate water much better that motor oil. However, the water must be drained off to be beneficial. I don't know how this would be done on a PT.
Viscosity stability appears to be the most important factor. High quality hydraulic fluids have much better viscosity stability when hot. This explains why we sense some power reduction on summer days when the hydraulic fluid reaches maximum operating temperature.
I believe PT said they used motor oil because it was commonly available (and cheaper of course).
/ PT Rises from the Ashes #15
<font color="blue"> I'm afraid Mossroad may have some catching up to do. </font>
Yep, it's pretty much a stattic site right now, as I haven't done anything to the unit lately. I'd better get going! /forums/images/graemlins/tongue.gif
/ PT Rises from the Ashes #16
Glad to see you've got the machine running again! I've had to keep my wife from reading your posts about PT's limited to absent assistance in the rebuild. We have had a very bad experience with a go kart manufacturer that we purchased an electric kart from who then gave no support when the machine didn't work right. (but that's too long a story to tell here). It's reassuring to know there is such an intelligent and active group out there to help if I do run into trouble after my (hopefully soon) purchase. db
/ PT Rises from the Ashes #17
John,
Any concern about the motor oil left in the circuit and/or implement motors mixing with the new hydraulic oil?. Probably not, just curious to see if you had any info on this.
Duane
smartguyz: <font color="green"> They use Mobil 10W-40. Terry said that they used to use hydraulic fluid, but after some issues arose where different people from different areas of the country found that they couldn't find the exact hydraulic fluid brand and viscosity PT was using </font>
Oh, that makes sense. Mixing fluids is not a great idea. Columbia Tractor doesn't stock 10W-40, I guess nobody uses it around here. Even Wal-Mart only has an occassional bottle. 10W-30 and 15W-40 are available. I was going to go with 15W-40 then changed my mind when I realized how far out of viscosity spec it would be for cold starts at 0 degrees F. 10W-30 gets too near the viscosity spec limit on the hot end to suit me - especially since this tractor runs so hot (the engine temp anyway - I haven't checked hydraulic system temps (yet - I just bought a noncontact thermometer)).
Put a much needed culvert in yesterday - sure is nice to be back at work,
Sedgewood
MossRoad: <font color="green">Yep, it's pretty much a stattic site right now, as I haven't done anything to the unit lately. I'd better get going! </font>
May I suggest getting going by acquiring some new toys rather than my calamatous approach which, effective as it may be, has proven to be a rather too traumatic way to acquire site material!? /forums/images/graemlins/tongue.gif
Sedgewood
duane: <font color="red"> Any concern about the motor oil left in the circuit and/or implement motors mixing with the new hydraulic oil?. Probably not, just curious to see if you had any info on this. </font>
I thought about this and decided not to worry about whatever might have been left in the wheel motors and cylinders - everything else has been apart. There was probably not more than 2-3 quarts still in the system which is only a 3% or so.
One thing that has concerned me more as I've read up on hydraulic systems is contamination. The PT 1845 system, and the other models too I assume, are simple in the extreme, with no filtration other that the 10 micron suction filter. There are no screens on the suction lines leaving the tank. Not even a filter on the tank vent. While I had the system empty I thought I might put screens on the suction lines but decided against it since there was no easy way to connect them because of the welded construction PT uses which doesn't provide pipe nipples inside to screw a screen to (see attachment).
I did put on a filtered vent cap though (next post/attachment). A vent desicant also might be a good idea to keep moisture out but I decided not to go that route for now muddy reasons.
Sedgewood
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A60736)
CAT FORKS W/ QUICK...
2014 INTERNATIONAL PROSTAR 6X4 T/A  SLEEPER TRUCK TRACTOR (A59908)
2014 INTERNATIONAL...
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A60736)
2013 POLAR TANK...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
John Deere 5090GN (A60462)
John Deere 5090GN...
