PT Implement Choices / Questions
/ PT Implement Choices / Questions #31
Well not really sure about the switch - I just thought that someone must make some sort of elctric valve that would be mounted inline before the hoses go to the PTO outlet - the switch would only control the direction of flow to the PTO - of course the ending flow would go the same direction internal to the machine
the mechanical one PT has actually mounts on the implement
( I have one for the tiller) - but I would like to actually build it into the machine with an electric switch
Oh the only motor that I know of that is not reversable
is the standard finish mower motor
/ PT Implement Choices / Questions #32
was not inferring any hints or insults, one thing i want and hope to be able to see myself installing, after i get my newest toy paid for: the 300 series topdresser w Hydraulics
is a <font color="red"> RED BUTTON </font> like Charlie has. this will make manipulating the Lackender backhoe, and thanks to Charlie the multitude of Knuckleboom attachments such as manure grapple much easier.
/ PT Implement Choices / Questions #33
</font><font color="blue" class="small">( A landscape rake. )</font> here is what PTRich did.
Look How Need http://www.tractorbynet.com/forumfiles/19-138354-Rake.jpg
</font><font color="blue" class="small">( Having never used such an item, I'm wondering if I am way off base...what I'm trying to do is, after clearing the trees and stumps, efficiently get the roots, rocks and such out of the way before tilling...is it worth the money? )</font>
to clear the woods or for that matter any other clean-up job, i would look into making, buying or renting (toro) a grapple bucket. i move sizeable trees, brush etc and thereafter cleanup the ground by backdragging with the grapple bucket teeth.
someday i will built an attachment like PTRich has made. am also looking forward to own a pt power rake but for the time being i will invest in a pt (120.00)and toro(400.00) quick attach plate and rent a harley rake from the local rental place.
Yea, a grapple for the bigger stuff for sure...I like your ideas /forums/images/graemlins/cool.gif...I'll need to get one sooner or later....in the mean time, for a "cheaper" rake, I was thinking of trying to find or make a removable "rake-bar"... basically tines well attached to a six foot strap of steel to bolt onto the existing "snow" blade. I've looked at some heavy tooth bars, some up to eight inches...that would probably do the trick dragged backwards, but the spring steel tines make more sense to me for raking up roots, small rocks, debris and such.
/ PT Implement Choices / Questions #35
I purchased a rake and box scraper from http://www.worksaver.com/ . I've used both for over two years in a prettty demanding environment and I've got no complaints. You make take a look to see if they have a rake that fits your needs.
/ PT Implement Choices / Questions #36
<font color="red">I was thinking of trying to find or make a removable "rake-bar"... basically tines well attached to a six foot strap of steel to bolt onto the existing "snow" blade. </font>
Here's how I modified my PT rake by replacing their wimpy tines with tedder tines - now it works great for cleaning out amongst the bushes. It's basically tedder tines on a bar - add a piece of 2 inch square tubing to the bar and slide it into your PT quick attach receiver hitch and away you go.
http://www.tractorbynet.com/forumfiles/54-208454-Modified-Rake.jpg
Sedgewood
RM, thanks for the great link. Their stuff looks well thought out and sturdy.
Looks pretty good. I'm thinking now of just buying tines to attach to the blade. Thanks for the insights.
/ PT Implement Choices / Questions #39
I would like to maintain my 400 gravel drive. I have been using the dirt/snow blade, the surface is 1" gravel, would the box blade be better? I own a 422.
/ PT Implement Choices / Questions #40
Hey John - what kind of tines are those? - they look just like the PT tines - where do you get them - are they similar to the york rake style - they look different
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
Chemical Containers Tank (A57148)
Chemical...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
HEAVYEQUIPMENT TOOLS (A60736)
HEAVYEQUIPMENT...
2014 Kia Sedona Van (A59231)
2014 Kia Sedona...
2017 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A59230)
2017 GMC Sierra...
