PT-425 on snow
/ PT-425 on snow #1
JerryK
Elite Member
Vanderbilt, Michigan, USeh?
Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
Howdy, new to this area of TBN. I have an old 1991 JD 420 20hp hydro [ about 1000 pounds empty ] that I put chains on the turf rear and 400 pounds of old AllisC suitcase weights on the rear to push snow with a 54" blade. [ I have two big tractors with snow blowers for the big snowfalls ] I was wondering how these Power Trac's do since they are four wheel drive? Do they have clearance for chains ? I was thinking of getting a PT-425 with turfs on it so the chains would work. Probably just get the 60" front blade, a set of forks, and the regular front bucket. The JD as set up will push snow until she stalls if you let it, but it getting time to repower and put money in things that have been leaking for years... I use the JD all summer long out in the woods, it;s my ' Buddy ' tractor that helps me do stuff. Thanks in advance...!!!
/ PT-425 on snow #2
They take chains. If you know that you are only going to use them on snow and ice, some folks have studded chains. Just don't get down to pavement, or you will be leaving scrapes.
They are a number of posts detailing where to get them when you have a PT. I believe that most users use net chains, but many get by with no chains. It does depend on what kind of snow you get and how steep your slopes are. My bet is that in Vanderbilt, you don't have much slope, and that the snow isn't powder.
Because these are all hydraulic drive machines, the do really benefit from preheating the hydraulic oil.
All the best,
Peter
/ PT-425 on snow
Thanks Peter. I would probably just get plain link chains without any studs or bars. I've done that route before and my barn cement still wears the scars. It would mostly be a summer ride, but I use a smaller tractor to help build up the base. I keep all my stuff in an unheated area right next to the center heated area in the barn. Seldom gets down below 32 unless I go away for a day or two. Thanks again.... :)
/ PT-425 on snow #4
I'll tell you my 2001 PT425 with turf tires and the 60" snow blade will stop forward motion and spin the tires well before any hint of stalling. To me, that means not enough traction. I've never run chains on that machine. In dry snow there's never a loss of pushing ability. However, in really wet heavy stuff, I've been stopped by just 6" and had to push it off to the side. Its all dependent on water content of the snow. My turfs do fine on our level paved drive. Going across any significant side slope, however, it will crab sideways downhill very easily in snow. Hopefully someone that uses chains will chime in and tell you the before and after affects of chains in snow on the 425.
/ PT-425 on snow
Thanks Moss, I have lots of months to dream....!!!!! :)
/ PT-425 on snow #7
word of warning... YMMV.
My PT doesn't have sufficient clearance to put chains on the front wheels.... they rub like crazy. Rear wheels are fine. I have always intended to make a wheel spacer to install when I needed chains.... and in the meantime, my solution was simply to flip the front wheels around (warning: extra stress on wheel motor bearings, possible early failure.... blah blah blah).
But the ultimate solution was move to the Puget Sound area. Haven't used my snow blade in the last 4 years.... or my chains....
/ PT-425 on snow #9
I didn't know you moved. I was just in Seattle yesterday. Will have to look you up next time I am up
/ PT-425 on snow #10
I've got the tall boy version of the 425 with bar tires......my drive is 1/4 mile stone mostly all with an incline and one steep section.......when I first got the machine I plowed without chains and it crabbed all over the place.....really difficult going.......I installed chains on the rear wheels and it makes a huge difference.....I'd like to put chains on the front but mine has full wheel covers and the front doesn't have enough clearance.........the rears just make it......dry snow I try not to let it get more then 8"......I've done 12+" but have to push it to the side every 20 feet or so or the machine will stall out going uphill........wet snow is like plowing wet concrete......6" max and even then I'll stall.......I love the machine but when you put a load in the front of it pushing against gravity the center pivot point becomes a weakness and you will crab....for me chains are an absolute must and I keep them on from oct to april........Jack
/ PT-425 on snow
I just have a 54" blade on the front of the JD 420 that I turned into kind of a snow push box. If I buy one next summer, it will mostly be used in the Spring/Summer/Fall, but needs to do light snow duty especially in early winter when I am building my base. I could get buy with a lighter duty cable or strap type chain, especially if the unit had all wheel drive. Pushing is not sometimes the worse part, it's backing out of the pile a little up hill on ice or wet slush that sometimes gets my JD stuck. I would be going with the turf tire like on the JD, that seems to work best with just about any type of chain unless you wanted to go studs. Thanks..!!! [ here is20hp a couple pictures of what I want the PT-425 to replace.. 4 AllisC 100 pound suitcase weights on back, chains on rear, and cheepo push box... 20hp Onan hydrostatic 2 wheel drive with two speed locking rear axle ]
/ PT-425 on snow #12
I'd think that once you try a power-angle plow on the FEL arms of a PT425, you'd be fairly happy....
Think if you could lift that pusher box on your JD 4+ feet up? I regularly (like back in the old days when we'd actually get snow in winter) pile snow up 6' high with my 2001 PT425.
Just curious as to the rear tire size on that JD. They look a tad taller than the PT425, but if they are close, maybe your chains could be re-used on a PT?
/ PT-425 on snow
The rears are Goodyear 26X12X12, about 24" high mounted. I could not find the PT-425 size yet..... but I am looking.. :)
/ PT-425 on snow #14
23 x 10.5 x12 on my pt422 I am sure the pt 425 is the same size
/ PT-425 on snow
Are those turfs??? If I bought a pt425 I would get turfs... Thanks...
/ PT-425 on snow #16
Mine has turfs on it but the ag tires would be the same size, I find the turfs to be pretty good in snow as long as it is not real deep.
/ PT-425 on snow #17
and thats why I love having the backhoe mounted behind me all the time.......gets me out of all the "situations" I tend to put myself into.....lol.....I think with light snow work and chains you shouldn't have any problem.......I've been through 12 winters with mine now and consider it the best investment I could have made.......Jack
/ PT-425 on snow #18
You would have missed me. I am up near Nanaimo on Vancouver Island... seems like I am up here every other week lately (work).
CONVEYOR BELT (A68842)
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
2007 Toyota Rav4 SUV (A66738)
2007 Toyota Rav4...
2022 John Deere 450K LGP Crawler Tractor Dozer (A66734)
2022 John Deere...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
