PT 1430 Hydraulic Trouble
   / PT 1430 Hydraulic Trouble #11
This may seem way to simple but wouldn't installing a bypass filter system in the hydraulic system eliminate all the filter problems on a PT?
   / PT 1430 Hydraulic Trouble #12
I believe that it could work, but you would have to reduce the pressure down to an acceptable psi. A bypass filter for each circuit would be ideal. The filter unit and adapter would run between $75. and $150.00 for each unit. I think the external filter cart set up to filter each day or once a week is the way to go. You could even filter new oil, why you say, because new oil is not filtered as well as you think.
They also have high pressure filter for 3000 psi circuits, but again they are not cheap. Since our PTO pump is running all the time, this would be the ideal circuit to put a high pressure filter with indicator, in line, before it gets to tank.
I think if someone came up with a kit to filter the PT's sufficiently, every owner would purchase one.
   / PT 1430 Hydraulic Trouble #13
   / PT 1430 Hydraulic Trouble #14
I have most of the makings of an external 120V filter setup but I still need to find a source for cheap bulkhead fittings. Once I get it up and running I will let you know how it works.
Ken
   / PT 1430 Hydraulic Trouble #15
DieselPower said:
You mean something like this from KleenOil. :) They have hydraulic preasure control valves that bolt directly to the bottom of their filter housing's. Makes installing them a snap. They include everything, the filter housing, bolts, bracket, hydraulic hoses and fitting's.
Kleenoilusa.com - Kleenoil Filtration System Filter units.
Kleenoilusa.com - Kleenoil Hydraulic System Hydraulic valve kit.
I finally found the 3 micron filter limit, and the half gal per min flow rate, but never did find the cost. It sounds like a good deal, if it has an acceptable cost level.
   / PT 1430 Hydraulic Trouble #16
What size filter housing are you looking at? I can get you the prices.
   / PT 1430 Hydraulic Trouble #17
Physical size, would have to be small enough to fit inside the engine cover of the PT's. In gpm, the amount of hyd fluid on some of the tanks is 10 gal, and larger ones are 20 gal. I noticed that the filters filter about .55 gpm.
   / PT 1430 Hydraulic Trouble #18
Dear DieselPower,
You've mentioned these units a couple of times. Pricing would be useful to know, so that people could make informed decisions. The units look great, but they also look as if they are targeted at fleet owners, who can amortize the cost over constant use.
I agree with JJ; if someone works out how to filter oil in the primary working circuits of the PT, it would be a great addtion to the tractor. We all know that the machines will last longer and perform better in their 'old' age if we have clean oil circulating.
J.J.: How is your filter cart coming? Have you thought about a pair of quick connect fittings to enable you to hook up your external filter to clean the oil in the hydraulic tank?
Have you looked at the Parker unit? They also make a 6000 psi full flow filter that might be useful for the PTO or drive filtration loops. Thoughts?
All the best,
Peter
   / PT 1430 Hydraulic Trouble #19
ponytug said:
Dear DieselPower,
All the best,
Peter
I think the filter units mentioned by DieselPower retail for around $650 while the Parker unit in the link in the quote retails for around $900.
Larger filter carts that include an electric pump and two filters are $1500-1800 as best as I can tell.
I have not had the time to call Terry but I do intend to get all 4 wheels off the ground and see if the linkage is working properly.
2009 Kubota RTV1140 (A57148)
2009 Kubota...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
12ft 9in Altec Service Bed (A57453)
12ft 9in Altec...
8ft Teakwood Live Edge Slab Table (A57454)
8ft Teakwood Live...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
2011 Forest River Crusader 320RLT 36ft. T/A 5th Wheel Travel Trailer (A56859)
2011 Forest River...
