PT 1430 Hydraulic Trouble
/ PT 1430 Hydraulic Trouble
I did get time today to set the PT on blocks.
The lever on the tram or trans. works fine on the forward push on the treadle. However, when I move in reverse, the lever hardly moves backward. I am beginning to think my problem may be in the linkage somewhere as some of you have suggested.
I did not disconnect the hydroback cable from the lever and manually move the lever. I will need to do this to further determine if the problem is indeed in the cable or linkage.
/ PT 1430 Hydraulic Trouble #23
I am sure you guys know this, although I did not see this posted. When I was shopping for a 1430 I called PT for some advice. Terry was out so another mechanic was answering some questions. He said that the treadle linkage on the older PT's was prone to issues. He went so far as to say I would be happier with the newer PT than the older PT. I did not ask details as I was just inquiring about service issues in general.
Carl
One other item I forgot to mention from the hydraulic shop was the owner told me if the wheels on the machine are lifted off the ground, a good indication of the condition of the wheel motors is whether a wheel is easy to rotate. I did this with my machine and they are very easy to turn. If the motors were alright, the wheels should be more difficult turn. Does this make sense?
NO it was not running.
I did talk to Terry at PT today and he told me to look for another hydraulic shop...it sounds as if this guy does not know what is going on, he said.
I also asked about the motor oil used in the hydraulic system as there is quite a thread on the subject here and he stated the oil is used for it contains many additives regular hydraulic fluid lacks. This is why PT uses motor oil instead of the hyd oil.
/ PT 1430 Hydraulic Trouble #27
I would think the combustion additives would be of little use. Terry told me one of the main reasons they used motor oil was because it was easy for people to get and cost less for the customer to change.
Ken
/ PT 1430 Hydraulic Trouble #28
I had the same problem, and removed the Hydro-back, which is a spring inside another spring and cleaned every thing and put it back together. There are pictures on the forum somewhere. I called Terry about adjusting the Hydro-back, and he talked me through the setup. It still doesn't seem right. It could be the cable also. That cable runs about $ 135.00. The new hydraulic shifter on the newer units is the way to go. There are three adjustments, one is up front in the forward linkage, and the other two are at both ends of the Hydro-back.
Yes, Terry told me about the newer hydraulic shifter. I asked if it could be adapted to my machine but he informed it would not be cost effective to do so.
In the owners manual there is piece on adjusting the hydroback. Perhaps when I get some free time I will check it out.
After replacing a broken hose on the 1430 yesterday, the linkage bolt broke attaching my treadle to the cable. I ordered new linkage...who knows, this may have been part of the problem....would be nice if it was.
My next route will be to replace the cable again to see if it helps the problems.
/ PT 1430 Hydraulic Trouble #30
He would be correct, engine oil does contain additives not found in hydraulic/utf type oils. Problem is the additional ones it does contain have no purpose except in a internal combustion engine. The anti-wear additives can be as high as 4-5 times higher in a UTF fluid then what would be found in a engine oil along with higher levels of anti-foam and friction modifiers. Engine oil has one place, a engine.
/ PT 1430 Hydraulic Trouble #31
Can you then explain why Parker-Hannifin tests and records the performance of their hydraulic wheel motors using 10W40 oil? Seems at least one manufacturer doesn't agree with you...
/ PT 1430 Hydraulic Trouble #32
There is some merit to what the owner said about turning the wheel motors. The only good way to test the wheel motor is to take it to a hydraulic shop and have them hook it up and try to stall it. If it holds pressure, the motor should be OK. The hydro technician might be able to tell you you the state of the motor, by how much fluid is leaking internally.
If you have one wheel jacked up, and you can turn the wheel fairly easy, there is a problem. This is true only if there is no leakage back through the system. Your wheel motor is acting like a pump. If you have all wheels off the ground, engine not running, and you turn one tire, does any other wheel turn? As I have said before, when I have both front wheels off the ground, and I turn one wheel, the other wheel turns in reverse. One wheel is acting like a pump, and the other wheel motor is motoring in reverse. Strange, but true. That front linkage on the tram cable has some adjustment and should be tight. The swivel joint may be worn out.
I have replaced the swivel joint today and the problem remains the same. I suspect the cable now but am not quite sure. Terry said the cable could be at fault but this is the second one and the machine only has 440 hrs on it. Do they wear out quickly? At $135 a pop I would think not but I assume it could.
/ PT 1430 Hydraulic Trouble #34
Because it's cheap and easy to get. Just because something works does not mean it's the best thing for the application. Let's look at the reverse. Would you run hydraulic oil or UTF in your engine? Probably not. The additive packages of engine oil and hydraulic oils are very different. The hydraulic oil or UTF is going to have a much higher level of zinc (with UTF having about 2X that of hydraulic oil on average), higher levels of anti-foam additives and usually is formulated for better water demulsability then engine oil.
I have also owned wood chippers throughout the years and they also run 10w-40 in the hydraulic system and specify the oil is to be used in the machines when replacing the fluid. So for now, I continue to be confused regarding which oil is best in a hydraulic system. I assume the manufacturers would know best.
/ PT 1430 Hydraulic Trouble #36
Can you test it without the cable. Sorry, I don't know your cable system, but there has to be a way to give it a tug at the source...
Carl
/ PT 1430 Hydraulic Trouble #37
Amen to that. BTW, here's a couple of pages of the Lube info for Simplicity lawn & garden tractors over about a 30 year span. See all the different ones that specify motor oil. Some specify hydraulic oil.
New Page 2
Lube (pg2)http://www.simpletractors.com/service/lube_pg2..htm
Interesting that someone trying to sell something knows more than the engineers who built it. :confused: :confused: To say "one size fits all" in disregard to the manufacturer's recommendation is pure ... well, I won't go there..... :eek:
/ PT 1430 Hydraulic Trouble #38
No, I wouldn't. I don't put 90W gear oil my engines, nor do I replace 90W gear oil with hydraulic oil (regardless what additives it might have), nor do I replace it with motor oil. I'd run what the manufacturers recommend.... and there is at least ONE of the wheel motor manufacturers, Parker, who tests their engines with motor oil, and approves it for use. I think a second one (White) also uses motor oil, based on SUS ratings, but I'm not sure. Char-Lynn approves it for use, though they apparently test with hydraulic oil, based on the lower SUS ratings specified.
Point is that some applications recommend hydraulic oil, some don't. Some are designed to operate with the lower viscosity that hydaulic oil has, some apparently aren't. Their specified service life (i.e MBTF) would be based upon the lubricant that THEY recommend...
IMO, arbitrarily changing to hydraulic oil, despite the manufacturers recommendations, would make just about as much sense as running Dextron in your car engine, despite the manufacturer recommending engine oil...
/ PT 1430 Hydraulic Trouble #39
Carl
Yes, he can put the unit up on jacks so the wheels are off the ground, then operate the lever manually that the hydroback assembly activates by cable when stepping on the direction pedals.
/ PT 1430 Hydraulic Trouble #40
Nowhere did I say one size fit's all. I'm not trying to start a argument. :) Just my input from the lubricants side of the argument.
Don't forget that hydraulic oils can be had in many more viscosity's than engine oils. You can get anywhere from a ISO 10 (lower than SAE 0W engine oil)all the way up to a ISO 1000 (about SAE 250 gear oil) and can also get them in the multi-viscosity variety.
My point is that you can get a oil in comparable viscosity that is actually designed to be used as a hydraulic oil. Not something that was designed to be something else, a engine oil. The hydraulic oil will perform better, operte cooler, last longer and reduce wear better leading to longer equipment life. Does the engine oil work as per equipment manufacturers spec's, sure it does but there is spec and then there is better than spec.
You also have to look at it from the equipment manufacturers point of view. Engine oil is readily available for anyone to find. Odd ball viscosity hydraulic oils usually have to be ordered. Joe down the street needs to fill up his equipment on a Sunday, the engine oil can be purchased at the corner auto parts store instead of having to order the oil and wait a couple of day's for delivery.
Besides, if equipment manufacturers design and spec their stuff to high it will never break and they will never sell any replacement parts. :D
2016 Chevrolet Trax AWD SUV (A59231)
2016 Chevrolet...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
2008 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2008 Godwin...
208735 (A60430)
208735 (A60430)
2011 Open Range 424RLS 42ft. 5th Wheel T/A Travel Trailer (A59231)
2011 Open Range...
2000 16ft T/A Utility Trailer (A59231)
2000 16ft T/A...
