Proud owner of a new owner's manual
   / Proud owner of a new owner's manual #51
Better interface with the hoses. Otherwise I would have a loop that would either be pinched or to tight of a bend.
Ya, I have yet to completely win the hose routing & management war on my install too.
   / Proud owner of a new owner's manual #52
They work great for box blades and forks!
I got the hydraulic fluid and filters done.
The large drain plugs require a 30 mm.
I drained and replaced just shy of 10 gallons.
I was surprised how the drain plugs looked.
Rear plug
Yes there are 2 distinct shavings on that magnet.
Front plug
The front axle I used a crescent wrench and replaced the Teflon tape on the fill and drain plugs.
It was a real pain in the butt to refill it.
I only cycled the hydraulics to purge them, I did not get to drive it around to see how the Kubota fluid works.
   / Proud owner of a new owner's manual #54
There should not have been any Teflon tape on that straight thread, the copper gasket provides the seal.
Only tighten enough that it doesn't leak
The axle only uses pipe treaded plugs with a square head.
   / Proud owner of a new owner's manual #56
Very nice work Adam and thanks for sharing all your detail!
I always wanted pallet forks but good gosh these things are a must have, top of the list first thing type of attachment!!
It just sucks that I only bought them because were moving in the next 2 months to Germany and I needed a way to load my 40x60 shop into a semi trailer for storage.
So sadly I will be selling the XR4046HC to some lucky guy/gal
When we come back in 2-5 years I will be buying a new one by then I think the very few items that LS is missing (RPM matching) will be addressed.
   / Proud owner of a new owner's manual #58
Well that sucks! Bought an LS cab tractor with cab... Then QA forks, now selling to move overseas. I'm sure a pay raise is in order to buy a bigger LS next time... LOL. Safe moving!
CT
2005 MERCURY Grand Marquis Sedan (A56859)
2005 MERCURY Grand...
JOHN DEERE CX15 BATWING ROTARY CUTTER (A52708)
JOHN DEERE CX15...
2008 Mercury Milan (A56859)
2008 Mercury Milan...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2015 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A58214)
2015 TROXEL 150...
2015 EAST MANUFACTURING ALUMINUM STEP DECK (A58214)
2015 EAST...
