Proud new owner
/ Proud new owner #1
Ace
Central MA
Kubota BX2230
Hi everyone, I am the proud new owner of a BX2230. It has a FEL, 60"MMM and a rear bagger. I haven't got a chance to use it yet, but have a question regarding removal of the MMM. I coudn't turn the left rear anti-scalp wheel inwards because it hit the rear tire(turf tires). Is this normal? I did remove it, but am concerned the deck may not be mounted correctly. I look forward to talking more with you guys.
Thanks, John
/ Proud new owner #2
Congrats on the fine purchase, I have a BX 22 and I can turn the wheels inward to take the mower off. Try if you haven't done so already to lower the mower nearly to the ground before turning the wheel inward, this will give the most clearance. If this doesn't work you may have an adjustment problem.
Greg Williams
/ Proud new owner #3
Don't worry about a thing.... I have the same problem with my BX22. I have found that changing locations and getting it on flat ground such as the driveway will make it easier. I have also found that sometimes I have to wiggle the deck a little. If all else fails just get a bigger hammer. Where in Central MA are you located. We have a "local TBN" chapter in Southern Central MA (Sturbridge) that meets every other Thursday at noon. Today was that "other". We would be glad to have you join us. Two hours of talking tractors with pros. I suggest that you read this thread. Important information for all new BX owners with MMM Decks...... MUST READ>>>>
/ Proud new owner #4
</font><font color="blue" class="small">( Hi everyone, I am the proud new owner of a BX2230. It has a FEL, 60"MMM and a rear bagger. I haven't got a chance to use it yet, but have a question regarding removal of the MMM. I coudn't turn the left rear anti-scalp wheel inwards because it hit the rear tire(turf tires). Is this normal? )</font>
I have the same thing with mine so I vote "normal"!
/ Proud new owner #5
On my BX1800 I just drop the mower deck down some so it has more room. If it is all the way up, I have a real hard time making it work.
/ Proud new owner #6
Don't forget to use the trick that the dealer does...use the FEL to raise up the front of the tractor while you're dragging the MMM off and on to the machine. (But don't put yourself under the machine under those circumstances!)
As to the clearance problem, I also have a "Very tight" clearance on the left rear anti-scalp wheel and have to manuver the MMM vertically to be able to rotate it into "skating" position.
/ Proud new owner #8
...money for a BX2230??? As the fella in "Dances w/Wolfves" said, "GOOD TRADE" Enjoy using the machine and the comraderie of TbN.
/ Proud new owner
Thanks for the responses. Sounds like its nothing to worry about. In regards to Junkmans question: I live about 25 miles east of Sturbridge. It would be great to meet with you guys, but Thursday at noon is near impossible unless I'm on vacation.
Thanks again, John
2011 Kenworth T400 33Yd. Side Loader Garbage Truck (A64194)
2011 Kenworth T400...
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
12' x 76" Tilt Flatbed Utility Trailer (A66285)
12' x 76" Tilt...
(UNUSED) HARDEE 28 BLADE DISC HARROW (A64278)
(UNUSED) HARDEE 28...
2024 Texoma 16ft. T/A Equipment Trailer (A64194)
2024 Texoma 16ft...
2016 280 Trailers Towable LED Advertisement Board (A64553)
2016 280 Trailers...
