Pros and Cons of Kioti
   / Pros and Cons of Kioti #62
Nothing runs like a Deere when being chased by a Kioti! I used the Signature line for a few years.
   / Pros and Cons of Kioti #63
I just 'ordered' mine - CK3510hst.
Got cruise control - I plan to brush hog 20 acres regularly...
linked pedal - leave it at idel and when you hit the HST pedal it throttles up..just like your car does. Think it will be quieter, save fuel, but nice for general driving around/loader work/trailer towing.
Loaded tires - included free. (washer fluid)
LED worklights I'll ad. Bought a set of 4 for last tractor, only needed 2.
Got 1 rear remote - mostly for hydraulic top link. BUT could, with a long hose, run it up front for snow blade or grapple. It's a center and detent - so can use it for left/right or just leave it on and put a second control elsewhere if it's more convenient.
Stabilizer bars..my kubota has no adjustment and never needed it..so didn't bother with it. The SE model includes it (and a lot more (but is $3500 up charge...)
My old kubota (74 L175) started all winter even at -4 with no heater...dealer says nobody gets them...
Mirrors - got them too - my neck/shoulder kills me when I do a lot of turning around for box blading and such. We'll see how well they work in the real world. $64 so not a budget buster.
And armrest for loader side..$84..maybe a waste but not sure, so why not?
I always liked the specs of that model. Here is what I would want on it if it wasn't already so equipped:
3rd function for a grapple, or one or two rear hydraulic remotes
3pt stabilizer bars and extendable lower arms
Rear wheel weights or loaded tires
engine heater?
Eeasy enough to add your own LED work lights
I just added a mirror to my tractor, which I used to think was silly, but I sure do like havig it.
Not sure how well it will go over putting red equipment on the orange page. Did go with JD, their paint is just too much $$$. Went with a Yanmar YT359.
   / Pros and Cons of Kioti #65
Yipee! I want one of those.
   / Pros and Cons of Kioti #68
Interesting. Learned something. However..
I got a quick hitch of titan - like pat's quick hitch. WAY better than all this - AND - neither of my tractors has the extandable lower link OR the pin type stabilizers.
I used to think stabilizer bars and extendable links were a luxury. I no longer think that. They sure make hooking up attachments easier.
   / Pros and Cons of Kioti #69
shrinking with age..so just under 6'.
Cab is nice, loved the kioti cab, but there's a cost to it (didn't ask...ye olde can't afford it so don't ask, right?)
I tend to get on and off my tractor a lot - hoping that will change with a hyd top link and a loader..and figured a door would be an issue for me - like i'd break it.
You should see me mowing grass with a ROPS..never had one before and well, slowly all th etrees are losing their lower limbs...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
530 (A52708)
530 (A52708)
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
1777 (A58374)
1777 (A58374)
2011 DRAGON 130BBL VAC TRAILER (A58214)
2011 DRAGON 130BBL...
2017 Genie GTH-5519 (A53317)
2017 Genie...
