Propane Tank Outdoor Storage
   / Propane Tank Outdoor Storage #11
There exists a heat cable known as 'self regulating tracing'. I've used it often to keep water lines from freezing.
Usually offered as 3 or 6 watts per foot and either 110 or 220 powered.
Only the cold areas get the heat so it is as economical as possible.
Experience has proven the 6 watt cable can actually thaw a frozen water line but the 3 watt version only prevents freezing.
Very easy to use/install, just splice the AC onto the tracing wire and good to go.
That type of cable combined with some sort of blanket would, I'm sure, be a reasonable DIY solution.
Even wrapping with standard R12 home insulation 'blanket material' would be a good start.
Also fiberglass blanket insulation, by their nature, are fireproof, but keep it dry or sheltered.
Another approach to propane service in cold zones is to install the tanks in a pit to take advantage of ground heat as frost levels are generally a known factor: in my area 4/5 ft is helpful.
Consider the goal is to keep that propane closer to 'warm enough' merely to allow vaporization.
Shucks even the eavestrough 'tracing cable' sold in many box stores would be better than nothing as a heat source (under a blanket of sorts)
Addendum:
For occasional use the addition of a programable 7 day timer might be a feasible addition.
   / Propane Tank Outdoor Storage #13
PROPANE AND COLD WEATHER
During the winter months, cold weather can wreak havoc on the propane sitting unprotected in its tank. The temperatures are much too low to allow the propane to sit unaffected. More specifically, freezing temperatures negatively affects propane in two ways.
Propane Depletion
When the temperature drops, propane can be greatly reduced inside the tank. The propane shrinks due to the unforgiving winter cold, leaving an unsuspecting person shocked to find the tank level gauge reads well below what it did before the winter hit. Once this depletion has occurred, the only choice is to refill the tank wasting precious time and money.
Loss of Tank Pressure
The pressure within a propane tank will drastically drop in cold weather as well. Propane is stored within the tank as a liquid, which is then released through a valve as gas. However, when temperatures drop too low within the tank, right around -44 degree Fahrenheit, the propane no longer has the ability to convert into its gaseous form.
The result? The propane cannot be extracted and sits utterly unusable within the tank.
Its the vaporization capacity that is reduced not the volume of liquid. Vaporization is the amount of liquid in contact with the steel which is warmed by the air and/or by the sun. At -30F you van hold a cup of liquid propane in your hands and watch it slowly vaporize......bigger the tank the more vaporization capacity you have available.
   / Propane Tank Outdoor Storage #15
Awesome 42 years in the gas business and I learn something new everyday.
That being said they are pretty expensive and I am not sure if the electrical classification would allow them to be installed legally in the New England States and NY
Thanks for the information.
   / Propane Tank Outdoor Storage #16
Addendum:
I don't believe that even the 6 watt per foot heat tape would do a lot with propane vaporization in sub zero tempertures, even wrapping 50 foot around a tank is only 300 watts or just over a 1000 btu.
And if you insulate the tank when it does vapor off gas it will chill the tank.
   / Propane Tank Outdoor Storage #17
When we lived in Glennallen, AK we had the 100# propane tank in a small enclosure. We found that around -15F to -20F the propane would not flow. We had a small heat lamp in the tank enclosure with a wall mounted switch in the kitchen. Get up - check the outside temp - if its down to double digit minus temps, flip the wall switch. In a short while you could fire up the kitchen stove.
   / Propane Tank Outdoor Storage #18
Using plexiglass to build your lean-to would be helpful when it's getting direct sunlight. Also a heat lamp controlled by a timer or thermostat. Hopefully before next winter there will be a lot of plexiglass being scrapped.
   / Propane Tank Outdoor Storage #19
Not much sunlight in Northern Ontario in the dead of Winter.
Very short days!
   / Propane Tank Outdoor Storage #20
Just wondering....
Vaporization should be affected by the surface area. Those 100 lb tanks do not have much. You might be better off with a permanent 250 gal horizontal tank. Bulk is also cheaper and you do not have to wrestle those 100 leers around.
BTW, I live in Northern MI. Have had -35 and never experienced a propane supply issue running an 80,000 BTU furnace. That was with a 500 gal tank.
RYOBI 18V BRUSHLESS ELECTRIC 16" PUSH MOWER (A51248)
RYOBI 18V...
2" X 3" ANGLE IRON UP TO 16' LONG (A51247)
2" X 3" ANGLE IRON...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
2012 INTERNATIONAL DURASTAR 4400 SBA 6X4 WATER TRU (A51247)
2012 INTERNATIONAL...
Polaris Side by Side (A50324)
Polaris Side by...
SPEECO SPLIT MASTER 15 TON PORTABLE WOOD SPLITTER (A51248)
SPEECO SPLIT...
