Propane Tank Outdoor Storage
/ Propane Tank Outdoor Storage #41
The farce of it all is when U need that propane to run your generator it is usually due to a power outage so all those precautions really don't matter, other than using ground heat. (buried tank)
/ Propane Tank Outdoor Storage #42
Does a 100 pound tank provide a sufficient evaporation rate at the lowest temperatures in your area to support your heater? That surprises me. Is it an option to rent maybe a 250 gal or 320 gal tank. They have a much higher evaporation rate.
When I replaced my 500 gal tank, (would not pass inspection) we discussed using 3 x 120 gal tanks on a manifold. That was because it was difficult to get to where the tank was sitting and we did not use a lot of fuel - 500 gal about every three years. But the 3 x 120 did not have a high enough evaporation rate to run the house at -10. So we bought a new 500 tank.
Yes, if you buy a tank, they are expensive. My new one was $2300. HOWEVER, the company wanted to lease on to me for $6 a month. I would have done that, but I like to choose which company I refill with. If you lease, you will have to refill from the leasing company. Then they can deliver with will call service. Some services companies may have an minium use requirement. But that might be discussable if you need the evaporation rate of a larger tank.
There is a propane services man's manual that gives the evaporation rate and btu that can be used with different tanks at different temperatures. I think here:
The rate of the surface area evaporation in the tank is the maxium that can be supplied to your heater or furnace. The vapor btu rate at coldest temperatures is the real first determining factor on tank size.
JUST A THOUGHT. Best wishes.
/ Propane Tank Outdoor Storage #43
There is plug-in thermo cubes designed for freeze protection that only kick on when the temp drops into the 35-40 F. range. You plug them into an outlet and the load into them. I have one set up with a 250w. heat lamp, in an insulated shed. It only burns electric when the outside temp is well below freezing.
/ Propane Tank Outdoor Storage #44
Another consideration.
High propane demand from a tank and using a small regulator (like BBQ size) can actually freeze up quite fast.
That phenomenon is from 'venturi effect'.**
Heck even automotive carburetors have some heat source to prevent that effect.
Early VW's had a summer/winter lever to cure that problem by deflecting some manifold heat onto the carburetor.
** air/gas that rushes thru a venturi will create enough cold to actually ice up.
Ahh yes, the rusted up heat riser valve.
The regulator should be sized to the flow rate.
A needle valve and propane at pressure allows one to fill a metal bucket with propane Liquid.
/ Propane Tank Outdoor Storage #45
Could you use structural insulated panels (SIPs) and cover them with some inexpensive exterior sheathing?
/ Propane Tank Outdoor Storage #46
Be aware that if the tank installation is not up to the local codes the Propane supplier will not fill your tank.
/ Propane Tank Outdoor Storage #47
If a 100 watt light bulb uses $10 per month in electricity it might pay to put in a thermostat to keep the temperature at the lowest point possible to maintain the flow. I've used this method to keep the utility room attached to townhouses from freezing. We used three 40 watt bulbs with a bypass switch. Turning on the switch for light, we confirm the lamps are working, turn off the switch and the thermostat would provide heat when needed.
/ Propane Tank Outdoor Storage #48
We used to use two incandescent light bulbs in series. The lower voltage gives you a much longer bulb lifetime. (Slightly more heat than one bulb at full voltage, as cold filaments draw slightly more current.)
All the best,
Peter
/ Propane Tank Outdoor Storage #49
I'm presently using 130V trouble light bulbs in the doghouses that contain extra supplies for the first responders. I recently changed two of them after at least four years of continuous winter use.
/ Propane Tank Outdoor Storage #50
Would an RV waste tank heater work. Some can be used at 120 volt or 12 volt. They have sensors that turn on/off at correct temps.
I have them on my RV and run them on the batteries.
/ Propane Tank Outdoor Storage #51
We lived in a small town for a year - Glennallen, AK. Doofy's stomping grounds - half way between Anchorage and Fairbanks. Yes - it got really damn cold there.
Our kitchen range was propane. In the winter - get up - flip a switch on the wall near the kitchen range. Turned on a heat lamp in the little shed that held the propane tank. Wait and listen..... About five minuets and you could hear the propane bubbling in the outside tank. Now you could turn on the range.
That year was an experience that I'm glad I had. Until you have to live in conditions such as that - you really don't understand what "tough" can mean.
Fortunately - in those type conditions - you have three choices. You adapt - you leave - you perish.
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
36in AIM Bucket w/ Teeth Excavator Attachment (A64194)
36in AIM Bucket w/...
EZ-Steer Controller and EZ-Steer Motor (A65640)
EZ-Steer...
Bucket (A64194)
Bucket (A64194)
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
