Propane heater
/ Propane heater #1
kevin37b
mansfield,Il
john deere
Anyone used the 5000 btu. cupholder propane heaters in a cab tractor ? I have a snowplow tractor with a Curtis cab and thought it might help on those really cold mornings . They screw onto a 16.4 oz bottle and pushbutton ignite . Appreciate any input . Thanks , Kevin .
/ Propane heater #2
I would be very cautious about carbon monoxide with something like that. If you try it make sure you have the carbon monoxide alarm in there with you.
/ Propane heater #3
I don't think that's such a very good idea. CO poisoning can sneak up on you & you just go to sleep. Next thing you know - its a dirt nap.
/ Propane heater #4
Propane makes a lot of moisture when it burns, as well as possibly carbon monoxide. You'd need adequate ventilation.
/ Propane heater #5
I recall JC Whitney used to sell little heaters that you would install them inline with a radiator hose. I always thought they would work decent in a tractor cab.
/ Propane heater #6
I use one in my golf cart (not used for golf, though, its a farm vehicle). Its really just a hand and body warmer. Plenty of free air around.
/ Propane heater #8
A 12v electric heater would work if you have a good size alternator.
My dad put one of those gasoline heaters in his '47 chevy when it was new. I had no idea they still make them. Sure was nice having almost instant heat.
/ Propane heater #9
I got one to use. It heats up the cab so well I have to open the door. Even the lowest setting is too hot. It will also make the windows fog up really bad. Another reason to open the cab door.
2021 CATERPILLAR 299D3 XE SKID STEER (A65053)
2021 CATERPILLAR...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2016 CATERPILLAR 303.5E2 CR EXCAVATOR (A65053)
2016 CATERPILLAR...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2016 Ford Explorer SUV (A64557)
2016 Ford Explorer...
2000 LINCOLN TOWNSCAR (A64278)
2000 LINCOLN...
