Problems with washing my JD4310 ePwrReverser
   / Problems with washing my JD4310 ePwrReverser #1
thedirtdoc
Wilderville Oregon
JD4310
Have any of you guys ever experienced the following...
Approx. 1-1/2yrs ago developed a problem with my 2005 JD4310. After spraying down the tractor, I literally could not get it to move. I found that if I depressed clutch, left transmission in neutral, and moved the reverser lever from neutral to drive and let out on the clutch, I could hear the hydraulic converter move as if engageing, but as soon as I depressed the clutch again and shifted into a gear, the hydraulic converter would disengage and it would be like I was in neutral (the low-high speed lever was engaged). This went on for a while and finally after things dried out aparently, the unit started to work normally.
About 1yr. ago and repeated calls to the dealer, JD authorized the dealer to replace the wiring harness and all fuses. This corrected the aparent problem temporarily, however after leaving the tractor on my trailor this past weekend during a thunder storm, I went out to unload it and experienced the same problem all over again. Now this tractor is out of warranty and the dealer told me to make sure the battery is disconnected and for me to pull every plug in the system and put some silicone on each connection. HELP!!!
   / Problems with washing my JD4310 ePwrReverser #2
I've had the same problem you're describing.Dealer had no real solution. I think he said "don't get water on the reverser lever or the fusebox."
Sorry I couldn't help more.
Mike Scheer
2004 JOHN DEERE 160C LC EXCAVATOR (A59823)
2004 JOHN DEERE...
Toro Sand Pro (A56859)
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
2017 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2017 CATERPILLAR...
