Problems with the "Freedom 42" mulching deck
/ Problems with the "Freedom 42" mulching deck #1
jmhines
Problems with the \"Freedom 42\" mulching deck
I have all of 5 hours on my LT160 with the Freedom 42 deck. In thos 5 hours, I have had nothing but trouble. 2 timing belts and 2 new sets of blades.... It will run great for a short period and then, WHAM, the blades start hitting each other , lock up and strip the timing belt. ANY suggestions are welcome.
/ Problems with the "Freedom 42" mulching deck #2
Re: Problems with the \"Freedom 42\" mulching deck
If the belt is jumping you either have a mis-aligned pulley or too little tension on the belt. More importantlly, at 5 hours the tractor/mower is almost brand new. I would be pushing the dealer to fix it, or replace the entire deck if needed.
/ Problems with the "Freedom 42" mulching deck #3
Who is putting the belts back on? You or dealer?
/ Problems with the "Freedom 42" mulching deck #4
I think the belt is installed incorrectly or something is badly bent. There are specific torque requirements for the tensioning system, so many turns or some such on the spring bolt and a specific torque requirement on another bolt.
Also if you put the blades on the wrong side (there is a right blade and a left blade) they can loosen by themselves and cause the problem you are seeing.
I've been running the exact same setup for 8 years and never had that happen. I did replace the belt once as preventative maintence. I hope you get it going correctly. The freedom deck is the greatest thing since sliced grass.
Cliff
Westfield Gravity Wagon Auger (A66408)
Westfield Gravity...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
John Deere 1530 Tractor (A66285)
John Deere 1530...
1995 Bulk 307 SS Insulated 6,500 Gallon T/A Chemical Tanker Trailer (A64194)
1995 Bulk 307 SS...
2010 Polar DOT 412 General T/A Chemical Tanker Trailer (A64194)
2010 Polar DOT 412...
