Problem with Tilt Meter
/ Problem with Tilt Meter #41
BigEddy,CTyner,
I am going to try playing around with weights. Might be fun.
CTyner, any idea where to get sorbothane??? I tried a rubber
supply house here, and they do not carry it. Thanks Guys. Rick
/ Problem with Tilt Meter #43
Yep...that's it. /forums/images/graemlins/smile.gif
/ Problem with Tilt Meter #44
Rick,
Following your thread with interest. You might try what the compound bow manufacturers have done to eliminate limb breakage. Look up Limb Savers. You could stick one on your meter and see if it helps. Certainly dampen vibration on mirrors and in other accessories other than bow applications. They look like a mushroom made out of a material similar to Sorbothane. I may have an extra laying around if you can't get one from a local sporting goods store. They come in several sizes as well.
/ Problem with Tilt Meter #45
It would seem that the static charge would be easy to prove. Simply hook up a wire, wait for the ball to stick and then ground the wire. Either it will or will unstick.
Is it possible that the temperature, humidity and vibration are causing the glass tube to change shape just enough to stick the ball?
Steve
/ Problem with Tilt Meter #46
Just grounding a wire connected to the tube will not work.
The wire would have to be connected everywhere on the glass or rubbed across the entire surface.
Glass is funny, its an insualtor however it can hold a static charge.
Since glass is an insulator the glass will only have the static discharged at the point of wire contact. Everywhere else will still have a charge.
You can see and feel this on your TV screen when dusting. You keep generating static discharges as you wipe across the screen. This is probably a good thing or it would be a hella zap.
/ Problem with Tilt Meter #47
CTyler,
HEY THANKS GUY. I CALLED SORBOTHANE AND I HAVE
SAMPLE STUD MOUNTS AND SHEETS COMING. WILL HAVE
THEM TUESDAY. PAUL, (APPLICATION ENGINEER) AT
SORBOTHANE IS CONVINCED THEY WILL CURE PROBLEM.
HOPE HE IS RIGHT. WILL KNOW SOON. I REALLY APPRECIATE
EVERYONES INPUT. STILL PLAYING WITH OTHER IDEAS
FROM TBN GUYS ALSO. THANKS EVERYONE!!!!! RICK
/ Problem with Tilt Meter #49
pruntyc,
I sent out 2 new meters today ups. One has a new oil, one
has sorbothane pads. I also sent a 1in. x 2in. sorbothane pad
to try under one you have now. Please let me know what you
find. Thanks, Rick
Hi again Rick, like I told you, I'm in this till we find it. And after that, if you can use some more testing on any other ideas you might want to try in the future. I'm retired, and have the time, and glad to help you sir. You are a great guy, as far as I'm concerned, not many men will give you your money back if it don't work. Most would say sorry, but it works for others so it must be your fault. So as soon as I get them I will test them and get back to you, on how they work. And on what works or what don't work. Thanks again.
/ Problem with Tilt Meter #51
I have never done business with a company that stood behind their product the way R&B does. They stand behind there product the same way businesses did years ago. If it is not right we will take care of it. My hat is off to Rick and Brenda for running the kind of operation that they do and I hope that their business continues to grow.
/ Problem with Tilt Meter #52
Rick,
Thats what makes this place so great. Not only did you refund his money (because it didn't work), you have sent 2 and maybe 3 new ones for him to try, plus new pads to try on the first one. I guess this says a lot about you and your company. Keep your ethics right where they are my good man. I remember meeting you and "Brenda...?/" at Louisville while Surge from Nebraska and I were strolling the show.
Jerry
/ Problem with Tilt Meter #53
Pruntyc,Jerry, and Jerry,
Hey guys, THANK YOU!!!!! Brenda and I both felt the same
way when we started the company. We are not only selling
a product, but we are selling our reputation as people, as well
as business persons. I'll be darned if we will sell our reputation
for any amount of money. The friends we have made doing
this is priceless. To think that 2 people can take an idea, and
$150.00 and turn it into a company is fantastic. It is because
we had people that gave us a chance, and we were not going
to let them or ourselves down. Those people were guys like
you.
Besides, my mom told me when I was growing up, "always do
whats right, or I'll take a hickory switch after ya!!!".
She's now 72, and walks 2 miles a day. She could probably
do it!. Don't wanna find out.
Only in AMERICA guys, Only in AMERICA!!! Rick and Brenda
2001 Sterling Single Axle Dump Truck SELLING OFFSITE (A62613)
2001 Sterling...
213137 (A64276)
213137 (A64276)
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A65563)
2008 Hino 268...
2007 TRAILMOBILE 53X 102 T/A DRY VAN TRAILER (A59914)
2007 TRAILMOBILE...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
