Problem with hydraulics
   / Problem with hydraulics #1
babzog
MF 1533
Hey folks
Tractor is a Massey Ferguson MF1533.
The other day, I was cleaning up some dead trees and such. I was approaching a brush pile with a load to add and seemed to have run into a branch that pinched the oil return hose from the power steering motor. Oil was gushing everywhere! I managed to get it out and parked on the laneway.
Today, I removed the little clamp that was pinching the rubber hose and refilled the tranny/hydraulic oil. Started up the tractor and I have no hydraulics at all. No steering, rear arms won't lift, loader is dead. There is no leak after the tractor is started.
The hydraulics were working when I stopped so I'm hoping the pump isn't shot and the problem is something simple.
Do the pumps on these tractors need to be primed? Any troubleshooting steps I can check out?
Cheers!
   / Problem with hydraulics #2
Hope it's something simple!
I do remember, when I did my first service at 50 hrs (incl. transmission fluid change), I thought I'd really messed something up because nothing would work... but it apparently just needed several minutes of running for the hydraulics to come up again. Had me scared for a bit, for sure. (Curiously, after the second service --@250hrs-- the hydraulics started to work very quickly after start-up....)
How long had you run it after fixing the leak and topping it off?
   / Problem with hydraulics #3
Is your tractor a sync shuttle or power shuttl? The sync shuttles had a bleed screw by the hydraulic pump you would have to open to bleed the air. Owners manual tells you how to do it.
It's a synchroshuttle. I had let it run for about 15 mins and still got nothing. I also saw nothing in the manual about bleeding the hydraulics (I was looking... maybe I'm blind? Page #?)
A poster in the hydraulic section mentioned about bleeding the hydraulics and mentioned a bleeder screw on the pump (see attached). I tried opening the left one, starting the tractor for a few seconds (then shutting down, tightening and restarting) but after seeing a few bubbles escape, i still have no hydraulics.
   / Problem with hydraulics #5
I had a 1533 hydrostatic and after I changed the hydraulic fluid, I always opened both bleeder screws with the tractor running.
   / Problem with hydraulics #6
You'll need more than a few bubbles. I would let it run about 10 seconds or unitll it gets primed. The one on the left is the one to open. Don't take the screw right out.
I let it run this AM for about 5 mins till I noticed the pump was starting to feel warm, then I shut it down. Nothing. Starting to feel nervous now. :(
Well, the dealer never called me back to see about service, so I called another farm supply outfit. They came down the next day (today) and quickly located the problem. The return line which had been pinched, was unserviceable. They MacGuyvered a temp fix until a new host can be ordered. They just called to say the tractor is running again. :thumbsup:
   / Problem with hydraulics #9
:thumbsup::thumbsup:
Glad to hear the problem's been located!
Yeah... I just hope that the dry running didn't screw my pump.
2020 DRAGON ESP...
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2020 HINO 268 26FT NON CDL BOX TRUCK (A59575)
2020 HINO 268 26FT...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A60429)
2024 CATERPILLAR...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
