problem with broken off bolt
/ problem with broken off bolt #21
The vast majority of the time .. same here... Only a few rare cases did I get some relief.. they were brass bolts into a steel casting holding down an inspection cover to a chain drive box on a piece of heavy equipment. I'll bet half the bolts backed out when the bit grabbed...
No super luck with the easy outs.. though have had them accidentally function a time or too. Mostly ZI have just had to drill them out going up a 64th or 32nd at a time hoping to miss the parent metal.. then getting a dental pick or oring probe to pick the threads out and pray i drilled straight
Soundguy
/ problem with broken off bolt #22
Sears makes a tool called a "bolt out" that might do the trick. Kind of like an easy out only it works on the outside of the head of the bolt. Look here.
/ problem with broken off bolt #23
I don't think it will help you at this point but for future reference, I have had a lot more success with "easy out" type tools that have a square cross section rather than the expanding spiral which is more common.
Truck Tractor (A61568)
2009 CHEVROLET C8500 DUMP TRUCK (A59823)
2009 CHEVROLET...
2021 CATERPILLAR 289D3 SKID STEER (A62129)
2021 CATERPILLAR...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
2014 HYUNDAI 53X102 T/A DRY VAN TRAILER (A59906)
2014 HYUNDAI...
2024 JOHN DEERE 85G EXCAVATOR (A59823)
2024 JOHN DEERE...
