problem with broken off bolt
/ problem with broken off bolt #21
The vast majority of the time .. same here... Only a few rare cases did I get some relief.. they were brass bolts into a steel casting holding down an inspection cover to a chain drive box on a piece of heavy equipment. I'll bet half the bolts backed out when the bit grabbed...
No super luck with the easy outs.. though have had them accidentally function a time or too. Mostly ZI have just had to drill them out going up a 64th or 32nd at a time hoping to miss the parent metal.. then getting a dental pick or oring probe to pick the threads out and pray i drilled straight
Soundguy
/ problem with broken off bolt #22
Sears makes a tool called a "bolt out" that might do the trick. Kind of like an easy out only it works on the outside of the head of the bolt. Look here.
/ problem with broken off bolt #23
I don't think it will help you at this point but for future reference, I have had a lot more success with "easy out" type tools that have a square cross section rather than the expanding spiral which is more common.
2014 Freightliner M2 106 Bucket Truck, VIN # 1FVACXDT4EHFV0598 (A65563)
2014 Freightliner...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
Grain Bin Spreader (A65640)
Grain Bin Spreader...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
2019 Chevrolet Silverado 2500 Pickup Truck, VIN # 1GC1KREG4KF129755 (A65563)
2019 Chevrolet...
25 Traffic Cones (A65583)
25 Traffic Cones...
