Problem with 4310 HELP!!!!!!!!!!!
/ Problem with 4310 HELP!!!!!!!!!!! #1
mscheer772
Hayward Wisconsin
4310 JD 2003
I can't get my 4310 with the e-power reverser to go into any gear. This happened after I washed the machine.I opened the fuse box and sprayed some water to get rid of some lime dust.
The day before while mowing the code reader displayed either 4 dots, 1 dot, then a dash, or, one dash,4 dots, then 1 dot.
Help!!!
-Mike-
/ Problem with 4310 HELP!!!!!!!!!!! #2
Help!!!
-Mike-
Pull your manual and see if any of the fuses control the e-Hydro. If so, it may have shorted out or blown.
/ Problem with 4310 HELP!!!!!!!!!!! #3
Hmm... something to do with electricity, no doubt. I was under the impression that error codes were numbered.
However, I've labored under alot of different impressions over the years.... and some were very wrong!
That said, I'd be on the phone talkin' with my local JD shop foreman or one of of the floor mechanics.
One of the very best investments that I made after getting a tractor was to get my hands on the OEM JD Technical Reference Manual for my particular tractor. It's got all the good stuff; wiring diagrams, hydraulic circuit diagrams!! I also picked up the Technical Repair Manual for the drivetrain, engine, etc.
Spent some quality time on Ebay... drove my wife crazy --- Oh well, I simply explain that it's necessary to keep HER horses happy!!
Let us know how things turn out ---
AKfish
/ Problem with 4310 HELP!!!!!!!!!!! #4
Fault code 41 is the seat switch open. Try checking the seat switch connector and circuit.
/ Problem with 4310 HELP!!!!!!!!!!! #5
Help me a little here... if you have an "open" seat shut-off error code while mowing --- how can you keep mowing?
Sometimes I'm simple enough that I simply don't "get it"...
Thanks.
AKfish
/ Problem with 4310 HELP!!!!!!!!!!! #6
I can't offer any advice for fixing your tractor, but maybe next time use an air hose instead of a water hose on your electrical system. JC
/ Problem with 4310 HELP!!!!!!!!!!! #7
AKfish said:
EDITED
AKfish
Amen on the manual!
/ Problem with 4310 HELP!!!!!!!!!!! #8
Help!!!
-Mike-
The fuses are in a box for a reason, so they won't get wet.....
Problem solved. I let the tractor sit for 24 hours,hopped on, fired her up,and drove Christina to the barn.Something that got water on or, in it must have dried off, and away we went.
Thanks guys.
-Mike-
/ Problem with 4310 HELP!!!!!!!!!!! #10
Time heals all wounds...
/ Problem with 4310 HELP!!!!!!!!!!! #11
My 4310 does the same thing just about everytime I wash it. I let it sit for 30 minutes to an hour and something dries out and it's fine. I have checked everything I can find and still don't know what it is that is getting wet and causing the problem.
/ Problem with 4310 HELP!!!!!!!!!!! #12
Pretty obvious something is getting wet...
Look for a cracked or torn boot (at a connector or switch). Next time you wash the tractor, keep the water away from the dash panel...maybe you can determine if a seal is torn or cracked there.
2018 Infiniti Q60 AWD Coupe (A61574)
2018 Infiniti Q60...
213074 (A64276)
213074 (A64276)
International 3 Row Bottom Plow (A64119)
International 3...
(1) 74"X49" TAILGATE (A64280)
(1) 74"X49"...
Portable Air Compressor w/Honda Motor (A64119)
Portable Air...
2016 Ford F-150 4wd 4 Door (A63689)
2016 Ford F-150...
