Problem starting my DK40
/ Problem starting my DK40 #21
Pur Animal,
Do you know what rod was bent? I do not know of any rods inside the injection pump. The older DK55 used a Bosch pump.
/ Problem starting my DK40 #22
k0ua
I know the glow plug circuit is operating properly. I ran all of the test possible on the circuit. I also know the glow plugs are all OK.
As for once the tractor is started, it will smoke heavily for about 5 to 10 minutes and slowly improve. As for the power, it appears to have a low power output but I cannot compare it to another Kioti DK55. I have an old Ford 4600SU which is rated by the PTO output at 53 HP. This old Ford, with twice the hours, just pulls a lot stronger.
Once the tractor is to operating temperature, it still starts hard but does not really smoke a lot.
The one thing I do not understand is the smoke color. My old Ford and my John Deere 310G backhoe will produce a little black smoke when under a heavy load. This would indicate a incomplete fuel burn. The Kioti will produce the white smoke under a slight load. Does this indicate quenching the charge?
/ Problem starting my DK40 #23
k0ua
Jim, I just don't know.. This is getting out of my realm. If you are convinced that the pre-heat and post glow functions are all working, and that the plugs themselves all heat, then you must go on to something else.
/ Problem starting my DK40 #24
White smoke is un-burned fuel (or possibly water), typical of poor injector atomization or a cold pre-chamber. Black smoke (carbon soot) is partially-burned fuel, typical of excess fuel for the available air.
159116 (A60430)
159116 (A60430)
Takeuchi TB290 (A60462)
Takeuchi TB290...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
2019 Chevrolet Tahoe SUV (A60352)
2019 Chevrolet...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A61307)
Snap-On Gold Medal...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
