Priming issues
/ Priming issues #1
Jimmybigwind
ZETOR 3340
Hi Folks
I have two Zetors 1995 6340 and a 1997 3340. I love them and have had few problems.
Now I am having to prime my 1995 6340 each morning for the last few years.
I have replaced all the fuel lines, checked the steel lines in the tank, cleaned all the filters.
I replaced the hand primer pump, installed new copper washers on the banjo fittings.
It seems to bleed down each night.
I can't figure out what is causing the problem with needing to prime it each morning.
Any help would be appreciated.
/ Priming issues #2
Try to install a one way valve in the fuel line or a electric fuel pump. You have a tiny leak in the fuel system, checked the valves in the feeder pump?
/ Priming issues #3
And it's a common problem on Zetors.
/ Priming issues #4
If it has a lift/supply pump, start there..
If its the "expensive" kind, look for an alternative. or simply replace it w/ a low pressure electric pump.
U can pressurize the fuel tank w/ some VERY LOW psi compressed air & LOOK for leaks.. sprinkle some baby powder on the lines & connections.. any weeping or leaking will show up in the powder.
/ Priming issues #5
The feed pump is a classic Bosch licence made by PAL, does not cost much.
Would by a one way valve and put before the pump, might be all he needs
/ Priming issues
OK I can try that I had the tank off tested the tank lines and could find no leaks, but if it is common problem I will
try the suggestions. My 3340 has given me no issues. I have had the tractors since new and they have
been the most trouble free tractors I have ever owned.
Thanks again.
/ Priming issues
Hi AGVG I owned a DB 995 for many years and a MF 165 my neighbor has a 1959 MF 135. I have worked on all of them.
When it warms up I will attempt to fix the Zetor 3340
/ Priming issues #8
I own a DB 995, a MF135 and a Zetor/ Ursus so have some experience with old iron, Zetors are quite easy to work on, designed in a different world without bean counters.
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2017 TAKEUCHI TL8 SKID STEER (A65053)
2017 TAKEUCHI TL8...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
2017 CUSHMAN REFRESHER GAS GOLF CART (A63276)
2017 CUSHMAN...
Caterpillar TL1055D (A62177)
Caterpillar...
