Priming issues
/ Priming issues #1
Jimmybigwind
ZETOR 3340
Hi Folks
I have two Zetors 1995 6340 and a 1997 3340. I love them and have had few problems.
Now I am having to prime my 1995 6340 each morning for the last few years.
I have replaced all the fuel lines, checked the steel lines in the tank, cleaned all the filters.
I replaced the hand primer pump, installed new copper washers on the banjo fittings.
It seems to bleed down each night.
I can't figure out what is causing the problem with needing to prime it each morning.
Any help would be appreciated.
/ Priming issues #2
Try to install a one way valve in the fuel line or a electric fuel pump. You have a tiny leak in the fuel system, checked the valves in the feeder pump?
/ Priming issues #3
And it's a common problem on Zetors.
/ Priming issues #4
If it has a lift/supply pump, start there..
If its the "expensive" kind, look for an alternative. or simply replace it w/ a low pressure electric pump.
U can pressurize the fuel tank w/ some VERY LOW psi compressed air & LOOK for leaks.. sprinkle some baby powder on the lines & connections.. any weeping or leaking will show up in the powder.
/ Priming issues #5
The feed pump is a classic Bosch licence made by PAL, does not cost much.
Would by a one way valve and put before the pump, might be all he needs
/ Priming issues
OK I can try that I had the tank off tested the tank lines and could find no leaks, but if it is common problem I will
try the suggestions. My 3340 has given me no issues. I have had the tractors since new and they have
been the most trouble free tractors I have ever owned.
Thanks again.
/ Priming issues
Hi AGVG I owned a DB 995 for many years and a MF 165 my neighbor has a 1959 MF 135. I have worked on all of them.
When it warms up I will attempt to fix the Zetor 3340
/ Priming issues #8
I own a DB 995, a MF135 and a Zetor/ Ursus so have some experience with old iron, Zetors are quite easy to work on, designed in a different world without bean counters.
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
CATERPILLAR TL642D...
John Deere 2 Row Planter (A65640)
John Deere 2 Row...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
