Prices on driveway paving
/ Prices on driveway paving #1
TuckR
Spokane, WA
Kubota L3302
Howdy folks. I used the search function but didn't find any results from the last seven years. I have about 250yds of driveway on my soon to be constructed home. I'd like to start budgeting for getting that paved. We will be doing a decent amount of snow removal in the winter, and that sure goes a lot easier on asphalt in my experience. Anyone driveways done recently and want to terrify me with what they spent?
/ Prices on driveway paving #2
Just a very rough number. My drive would be about 650 sq yd. The added roughly 2 inches of asphalt over the old asphalt which was still intact but had some cracks they repaired. They also roto milled against two different concrete pads so there wasn’t a big lip. Roughly $20k.
/ Prices on driveway paving #3
I have asphalt now. Would never pay for it again. We are about to concrete our 1000 feet.
/ Prices on driveway paving #4
Costs will vary regionally - neighbor had a new drive (was prepped packed and graded so minimal work to pave) paved last fall 400' long with turnaround - total about 6500 SF with 2" base and 1" top coat $13500, or $2 PSF.
If you are building a new drive, the base and prep work is most important - suggest getting a good base 6" and compacting that for the first year then paving the second year once it settles.
We were going to redo our drive at the same time, and for 5000 SF, with asphalt removal, regrading and paving was $15K or $3 PSF.
/ Prices on driveway paving #6
$2 sf once base is already done.
/ Prices on driveway paving #7
Don’t pay the whole bill until you are satisfied and get everything in writing. We just got burned doing millings over the existing gravel. Not done to spec and contractor will not finish the work. Not enough hold back on our part.
/ Prices on driveway paving #8
275 yards (825 lf) x 12 ft wide=1100 sq yards, at 1.5" or roughly 165#/sy; 91 tons of asphalt; at $165/ton, plus $5000 mobilzation=$19,975.
All of that is pretty much based on some assumptions. 1.5" of SP-12.5 (or SP-9.5) on top of graded, compacted base (already in place; if not, figure approx $4500-6000 for 6" of base material, graded, and compacted, or roughly $15-20/ton; delivered, graded, compacted, heavily dependent on distance).
/ Prices on driveway paving #9
1000 LF of concrete, 12 ft wide, x 6" thick; 225 CY of concrete; not counting any labor grading and compacting subgrade, no labor for the pour, 100% easy access, zero pumping, your at $33,750 in Material; figure $1500 in forming material, $3,000 in labor forming, and then $6200 in pour labor; your Atleast $44,560; and those are pretty low numbers for the labor. Doesn't include Any grade work.
/ Prices on driveway paving #10
Most of the issues people have with asphalt fall into a couple categorys:
1) they get ripped off by what we refer to as asphalt gypsies; you pay for 1.5" or 165#/sy, and they give you 1/2"; they are long gone before you realize you got hosed, and that pretty drive falls apart
2) base and or subgrade; asphalt is a flexible material, and the majority of the strength of the system comes from the base/subgrade; which should be sufficient thickness (6" for a residence should be fine); compacted (98% density); organics/plastic materials removed;
3) Trees; no trees within 8 ft of the edge of the roadway; and the tree roots of any trees cut/removed; any dead roots will decay and leave voids; any living roots will grow, expand, crack/heave the asphalt
4) water and/or drainage; keep the water out of the base, and fron standing on the asphalt.
/ Prices on driveway paving #11
Some comparing of the pros and cons of asphaltic concrete vs Portland cement concrete:
Pros:
Concrete: wear and weather resistance, no base needed (just good clean, compact subgrade); no special equipment need to form/pour
Asphalt: cost, speed, the ability to tack and resurface, or mill and resurface; tends to not drastically heave when it cracks; moderate bump; smooth ride; immediately drivable
Cons:
Concrete: cost, worse ride quality, much more difficult to do major repairs; min 24-48 hrs after piur till you can drive (atleast 7 days for heavy vehicles); not affected by spills/chemicals
Asphalt: fewer contractors/suppliers; shorter 7-14 year life span (can easily be much more for residential); large equipment needed; chemical (petroluem) can/will damage asphalt;
The mobilzation on asphalt is a significant cost, making it expensive in small quantities; but getting cheaper as the job gets larger. Concrete requires almost zero real mobilzation. 3 guys can easily form and pour a typical residential drive in 1 or 2 days; with zero equipment.
/ Prices on driveway paving #12
All of the asphalt driveways around here just don't hold up. I have asphalt now. It probably needs to be resurfaced or something done but I'm just not going to put anymore money in temporary fixes.
/ Prices on driveway paving #14
I don't see concrete or asphalt driveways until I get into town. My driveway - mile long, gravel. Lower cost - easy to repair/maintain.
42 years ago - $16.5K to build my driveway. Now - at least 3X or 4X or more to get the same job done.
The entire mile of driveway had to be completely built. There was nothing here except the neighbors barbed wire fence - running down the section line.
/ Prices on driveway paving #15
One of my clients works at the Asphalt company here in Tyler TX. She told me that when hiring somebody to pave a driveway, you have to know what you want in your mix, or they can cut corners and use a cheaper mix that doesn't last very long. This is very common with driveways. The State, County and City all have very specific mixes that they require that are considered the best, but also the most expensive.
Another clients of mine works for one of the local paving companies and his personal driveway is asphalt. It's cracking and developing potholes. He is going to tear it out and install concrete. He said that even with the best materials, asphalt requires too much maintenance and money to keep it in shape.
One of the issues with asphalt is that it needs a curb or border at the edges to keep it solid. If you do not have that, then it will move a little on you over time, and develop cracks. Small cracks lead to big cracks. The wider the driveway, the less this happens, but the cost increases dramatically. One foot of pavement outside the width of your tires isn't enough, you really need two feet or more on either side to stop the spreading and movement of the pavement when you drive on it. And if you drive off of the pavement, that area needs concrete to hold the pavement together.
In my opinion, anything is better then gravel, but if you are going to pay for something nice, concrete done correctly will last the longest.
/ Prices on driveway paving #16
If your really looking to spend $30-50k on a driveway; it worth the time/expense/effort to have a contract, with a spec, material call outs, and some Geotechnical testing.
For a residential, asphalt driveway, in my part of the world (that affects the terms used) I would spec, subgrade to be stripped of organic materisl/top soil, proof rolled, and shaped to the finished shape, then 6" of limerock, LBR100, from an approved pit, compacted to 98% density, primed with asphalt emulsion prime (I like Special MS), and than, 165#/sy of Superpave Sp-12.5, traffic level-b, rolled with a min 4 ton roller.
The density testing would require either a pit proctor or a proctor and LBR pulled (cost you about $500 and 3 days wait), and then a density taken every 500 lf at a random location (that'd gonna be about $120 per test, with a 3 test min, or about $360). Yes, you dropped $900 in testing, but you have a leg to stand on.
If your contractor doesn't understand any of the terms (or he'll, if he starts talking about square feet) I'd run away. The terms vary area to area, so, down load a copy of your local county/city/state DOT standards, or local Land Developemnt Code; work if building a home, have your EOR write the spec for the driveway. Just understand your driveway is not a road, and a road spec like (tyoical FDOT) 12" stabalized subgrade LBR40; 10" limerock, LRB100; 2.5" SP-12.5 and 1.5" FC-12.5; traffic level C; is not needed for a home drive; that's designed to carry 10,000 plus trips per day, for 7-14 years.
Most guys doing small work for homeowners are a iffy lot at best.
/ Prices on driveway paving #17
Not to keep going on a rant; you wouldn't go to a home builder, and say, "Build me a 3 bed/2bath stick frame house, right here" and just show up 6 months later, and hope for the best. You would have a plan and spec, inspections, reviews, progress payments, ect. A $30-50k driveway isn't that much different, except the average builder doesn't know anything about asphalt/base, ect.
Someone mentioned brick pavers.... unless you are a multi millionaire, who hires out maintenance; DONT Do It. They are more expensive, ride worse, don't last as long, and are high maintenance; but they do look nice.
/ Prices on driveway paving #18
If your contractor shows up with just a plate tamp, or a 1/2 ton static yard roller, you're in for a screwing...
People will argue if priming the base is needed, I like it, and it's required for roadwork, but many people don't worry about it for parking lots/driveways; as it's most prevent the asphalt from sliding on the base from traffic.
/ Prices on driveway paving #19
"One of the issues with asphalt is that it needs a curb or border at the edges to keep it solid. If you do not have that, then it will move a little on you over time, and develop cracks."
This can be true or not; but if there isn't a curb, you want the base to extend 6-12" beyond the asphalt (EOP). That would be something shown on your typical cross section of the plan or spec.
Ag Spray 3pt 500 Gallon Boom Sprayer (A60462)
Ag Spray 3pt 500...
2026 Kearney 102" x 32' Gooseneck (A60462)
2026 Kearney 102"...
Giyi Gy-72 QA Mulcher (A60463)
Giyi Gy-72 QA...
John Deere TX Gator (A60462)
John Deere TX...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
