Disc Harrow Price and use question
   / Price and use question #1
Trophyduck
Maryland
LS XR4145 (45hp HST)
I don't know much about discs...my dealer has a 6 ft LS (pittsburgh) disc, 20 in discs, tube constructed.....says listed 4 2500 will give to me 4 1800. Is this a good deal? Prices are all over the place depending on make, model, etc.
Also, I'm only doing food plots and the occasional light discing to overseed my paddocks. Would a cheaper lighter weight disc be all i need or is it a "get what you pay for" kind of thing?
Thanks
   / Price and use question #2
What kind of tractor hp wise are you using? With a disc: weight is king. Looked at them on Rural King web site. Looks like a decent disk. However you may want to look for a used one. But buying used you need to be sure bearings and axle parts are available. Blades should not be an issue.
45 hp
   / Price and use question #4
sorry about that
LS XR4145..45HP Hydro
   / Price and use question #6
Over a ten year period $1800 works out to $180 per year. If I thought it would be worth that per year to have, I would get it.
Used will be cheaper, but be sure it's only used, not worn out.
   / Price and use question #7
TractorData.com
LS XR4046
2013 - XR Series
Compact Utility tractor
Series back: LS XR4040
Production:
Manufacturer: LS
LS XR4046 Engine:
Shibarua 2.2L 4-cyl diesel
LS XR4046 Power:
Engine (gross): 46 hp [34.3 kW]
PTO (claimed): 37.3 hp [27.8 kW]
Capacity:
Fuel: 10.5 gal [39.7 L] (ROPS)
12.4 gal [46.9 L] (Cab)
3-Point Hitch:
Rear Type: I
Control: position and draft control
Rear lift: 2756 lbs [1250 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 540 (1.375)
Mid PTO: independent (optional)
Mid RPM: 2000
Dimensions & Tires:
Wheelbase: 69.4 inches [176 cm]
Weight: 3870 to 4330 pounds
Front tire: 9.5-16
Rear tire: 13.6-24
Mechanical:
Chassis: 4x4 MFWD 4WD
Steering: hydrostatic power
Brakes: wet disc
Cab: Two-post foldable ROPS. Cab optional with air-conditioning.
Hydraulics:
Pump flow: 8.2 gpm [31.0 lpm]
Total flow: 12.4 gpm [46.9 lpm]
Steering flow: 4.2 gpm [15.9 lpm]
Page information:
Last update: May 30, 2014
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
   / Price and use question #8
Your XR4046 is an increment heavier than my Kubota L3560.
XR4045 ~~ 4,100 pounds, bare tractor. L3560 ~~ 3,700 pounds bare tractor.
Your can pull a Disc Harrow as wide as your tractor with pans 20" in diameter in all conditions. For food plots 9" pan spacing is preferable to 7" pan spacing.
If you have loaded rear tires and R1/ag tires I believe you can pull a Disc Harrow with pans 22" in diameter under most conditions. If you bog a bit on second pass you can hydraulically raise the Disc Harrow a few inches to decrease draft force resistance.
In ground engagement work WEIGHT IS YOUR FRIEND.
MORE: https://www.tractorbynet.com/forums/attachments/332493-tandem-lift-disc-harow-monroe.html?highlight=
Well I decided to pull the trigger. Going to get the LS (Pittsburgh Taylor) disc. I figured it's a good price although more than I planned for at this time....but worth it in the long run. Stronger, heavier, last longer.
2025 KH72 72in Hydraulic 4-Way Clamshell Skid Steer Bucket (A55851)
2025 KH72 72in...
2015 Chevrolet Express Shuttle Bus (A55852)
2015 Chevrolet...
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
2008 CAT 305C (A53317)
Misc Gas Equipment (A56469)
Misc Gas Equipment...
DIRT DOG GRB72 72" GRADER BOX (A57192)
DIRT DOG GRB72 72"...
