Pressure Washer
/ Pressure Washer #1
lizzie13195
Maysville,North Carolina
allis chamler b-John Deere870 tractor loader
Can a pressure washer pump be converted to use on a hydraulic pump? If it can what do I need to change about it?
/ Pressure Washer #2
No, not a good idea. Heat would be the major problem.
The plungers on some pressure washers are ceramic. Don't know of a mineral oil based hydraulic pump that used ceramic plungers.
Are you asking if a pressure washer pump can be used as a hyd pump. Actually it is a hydraulic pump, but using water as the medium.
There have been test using pressurized water to drive a water /hydraulic motor. A lot of stainless steel, and special seals were used.
2021 MOROOKA MST2200VDR TRACKED DUMPER (A65053)
2021 MOROOKA...
2003 Jeep Wrangler 4x4 SUV (A64557)
2003 Jeep Wrangler...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
JOHN DEERE 7420 TRACTOR (A64278)
JOHN DEERE 7420...
BESTWAY AG 1600 GALLON NURSE TANK (A64278)
BESTWAY AG 1600...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
