Pressure Washer
/ Pressure Washer #1
lizzie13195
Maysville,North Carolina
allis chamler b-John Deere870 tractor loader
Can a pressure washer pump be converted to use on a hydraulic pump? If it can what do I need to change about it?
/ Pressure Washer #2
No, not a good idea. Heat would be the major problem.
The plungers on some pressure washers are ceramic. Don't know of a mineral oil based hydraulic pump that used ceramic plungers.
Are you asking if a pressure washer pump can be used as a hyd pump. Actually it is a hydraulic pump, but using water as the medium.
There have been test using pressurized water to drive a water /hydraulic motor. A lot of stainless steel, and special seals were used.
2017 Toro GrandStand 52in Stand-On Mower (A64553)
2017 Toro...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A64553)
2025 BrushFox...
MARKER LIGHTS (A64276)
L6060 Kubota For Sale
NEW IDEA 2R CORN PICKER (A64278)
NEW IDEA 2R CORN...
PALLET OF WHEEL SPACERS & WEIGHTS (A64278)
PALLET OF WHEEL...
