Pressure Washer to Sprayer Conversion
   / Pressure Washer to Sprayer Conversion #1
bostonrats
Hello to all,
Here's a cheap and quick way to make a powerful sprayer.
Aquire or reuse your pressure washer. I used mine for the sprayer and around the house for years. Feed the pressure washer from a trash can or barrel. I used a hose out a tight cut hole in the bottom. Not sure if the pump will self prime for top feed. Mount the system on a cheap four wheel garden cart or what ever you wish. I picked up this cheapo at Home Depot. Pull with mower or by hand.
I had two systems for agitation, first was a 12 volt pump from an RV fresh water system. Second was to hang an air caddie on the cart and slow leak to the bottom. The air bubbles do a fine job...but you eventually run out of air. I was able to match the leak to my spraying and fill the liquid and air at the same time.
This will be a high pressure, low volume system. It give good coverage and a long throw. Since it's low volume it takes a bit of time to get everything wet, but not too long. I've shot Roundup and Imidian with this system with not issues.
That's it. Cheap and easy.
Here are some photos.
Best to all.
   / Pressure Washer to Sprayer Conversion #2
I hooked my pressure washer up to my sprayer before but the sprayer was not up to the output of my pressure washer. So I guess gravity feed is enough to supply the washer then.
I need to spray some swampy ground with some skeeter killer this summer, I can't drive out into it and the sprayer won't reach. I planned to use a pump and a barrel to supply the pressure washer. I may have to try it without the pump.
   / Pressure Washer to Sprayer Conversion #3
Nicely done, but what do you have to hide by covering yourself up? :D
I would say it's so that I'm not getting calls from all your girlfriends and wives... :eek: but it's really because I was so fat in the photo I'm ashamed to show it! I've lost most of it since then!! :cool:
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
John Deere 5055E (A53317)
John Deere 5055E...
Rotating Brush Sweeper Tractor Attachment (A59228)
Rotating Brush...
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
