Pressure Washer Attachment?
/ Pressure Washer Attachment? #1
Hook
Milford, NJ
Kubota L3010
Is there such a thing as a pressure washer attachment that uses a 3PH? It would seem like a natural to have one with wheels & a large tank & use the PTO to power it.
Hook
/ Pressure Washer Attachment? #2
Hook
I have seen several advertised but the only one I can find reference to is here <A target="_blank" HREF=http://www.lawrence-edwards.co.uk/pages/ancillary.html> PTO Pressure Washer </A>. Is that the kind of thing you were thinking of? I think the others I saw were larger, I will see if I can find the sites for you and will see if I can find any references to suppliers on your side of the pond.
/ Pressure Washer Attachment? #3
Hook
I found another one which mounts onto the 3PH. <A target="_blank" HREF=http://www.lloyd-jones.com/store/cleaning/pto3030a.html> Link </A>
Poster: Andyfr
Subject: Re: Pressure Washer Attachment?
Yes, this is the kind of thing I'm looking for. Now if I can just find one in the USA ...
Hook
/ Pressure Washer Attachment? #5
Hook
I have just found this item on Northertool.com in the USA, it is $119.99. <A target="_blank" HREF=http://www.northerntool.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1046&prmenbr=6970> PTO-Driven Rotary Pressure Pump Kit </A>.
They also do another one at $139.99 <A target="_blank" HREF=http://www.northerntool.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=1058&prmenbr=6970> PTO Pressure Pump </A>
Hope this is of use
Regards
Poster: Andyfr
> USA, it is $119.99. PTO-Driven Rotary Pressure Pump
> Kit .
> They also do another one at $139.99 PTO Pressure
> Pump
This might be just the ticket. Thanks.
Hook
/ Pressure Washer Attachment? #7
In regards to the
Self-priming pump pulls water from any source. Ideal for disinfecting, fire fighting, transferring diesel fuel and more. Fits directly to the PTO shaft of all tractors. Moves 1440 GPH at 540 RPM. Maximum pressure 425 PSI. 24 GPM maximum flow. Features a non-corrosive steel impeller, full face rotor and a patented seal. One year limited warranty.
with a max pressure of 425 psi, I am not sure that this will work too well for a pressure washer. Even the smallest pressure washers I have seen are at least 1500psi. This pump seems better suited to high volume fliud transfers, and not to low volume - high pressure applications like a pressure washer. Just my .02
2017 Dodge Grand Caravan Van (A61574)
2017 Dodge Grand...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
PALLET OF SCRAP AND TIRE (A63291)
PALLET OF SCRAP...
NEW HOLLAND 254 HAY TEDDER (A63291)
NEW HOLLAND 254...
LOOK! (A63111)
LOOK! (A63111)
2018 HINO 338 4X2 S/A 26FT CDL REQUIRED BOX TRUCK (A59912)
2018 HINO 338 4X2...
