press brake die angles?
/ press brake die angles? #1
lostcause
Maine
i'm tired of the bench vise heat and bend approach, so i'm going to build a simple press brake to use in my shop press. i've looked at a bunch of pictures that people have made, and my only question is the die angle.
i've seen a lot of pictures where people have used two round rods as a lower die, and i may do that for now as a simple stop-gap solution, but i want to make a 4 sided lower die once i find a piece of suitable steel around.
my question is: what is a good angle for the lower and upper dies? i'm thinking somewhere around 80-85 degrees for the lower - does that sound about right? also, should i make the upper die to the same angle, or should it be a little less, like 75-80 degrees? obviously, since this is just an attachment for a small tonnage shop press i'm planning on an air forming setup, which is why i assume i want the angles to be less than 90 degrees.
/ press brake die angles? #2
I would say 80, maybe 85 even. Just took a picture for you.
/ press brake die angles? #4
How many degrees did you get shield, sorry I cant see on my phone.
/ press brake die angles? #5
I don't use the break a whole lot, but it does came in handy once in a while.
I built some wheel guards for the lawn sweeper a few months ago. When my wife gets on the lawn mower with her books on tape plugged into her ears, she never looks where the wheels are when making a turn:mad:! So it was either build this or keep buying wheel assembles!:rolleyes:
2021 Tesla Model Y Long Range AWD (A61574)
2021 Tesla Model Y...
2019 F150 (A61306)
2019 F150 (A61306)
HOLLAND 4R FINGER TYPE SETTER (A63291)
HOLLAND 4R FINGER...
Generator (A61572)
Generator (A61572)
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
2 Row 3pt Bedder (A64119)
2 Row 3pt Bedder...
