Premium Diesel... ?
/ Premium Diesel... ? #22
Filled up my jug today and wound up filling with premium diesel instead of regular diesel.
1*Is this ok for the Kubotas? I would assume so... but I want to double check.
I know with regular gas the premium is usually a higher octane specifically for higher compression motors.
2* Is premium diesel similar?
Where do you live and where did you get the 'premium' diesel at? Did they say what made it premium?
3*Only diesel you can get today for on road use is ULSD, #1 or #2 or mix depending on where you live and what time of year it is.
4*For off road, you can still get LSDF at co-op's and fuel distributors. Philip.
5*I have never heard of premium diesel fuel. #
6* 1 for winter and # 2 for summer.
7*It will run fine on kerosene which is #1 diesel
1*There's only 1 fuel not 2.
2* See 1.
3*Almost correct but not quite.
~~ 95 percent is Both on road and off road ULSD.
4*That supply is running out cause they ain't making any more of it .
5*There is no suich thing.
6*The only difference between #1 for winter and #2 for summer is they add kerosene to the deisel for the winter.
7*kerosene is not #1 diesel
/ Premium Diesel... ? #23
I hate the big nozzles.
U can't fill a plastic 2 or 5 gallon can with them .
You can't easily fill an '02 Silverado either. I use a cut off oil plastic oil bottle as a funnel/adapter. Cut off about 1/2 of the bottle & jam the nozzle into bottle neck. Still a pita as it bypasses the overfill mechanism. MikeD74T
/ Premium Diesel... ? #24
Some years back a Texaco at my exit had "Premium Diesel" only.
Later an Exxon opened across the street. The Texaco lowered their price but also removed the word Premium from their diesel pumps. Supposedly the Premium Diesel had extra additives for cleaning, hight cetane etc.
/ Premium Diesel... ? #25
They tried the "premium diesel" rouse around here years ago.
Once, when I was young, I asked a baker what the difference between the $1 loaf of bread, and the $2 loaf of bread was.
He said, "There really is no difference".
I said, "Then why is there two different prices for the same bread"?
He said, "Some people want to pay $2 for their loaf of bread".
Premium diesel is a $2 loaf of bread.
Like the guy who insists on buying premium fuel for a car, that was built to run on regular, you will never convince them they are wasting their money.
Remember what P. T. Barnum said. :thumbsup:
/ Premium Diesel... ? #26
west Tennessee, We have two grades here, One is for the newer road use vech. it has no sulfur content or verylow for emmisions control. Older units still have the regular fuel. I haven't seen any Bio-fuel or #1 fuel. Our long term fuel tanks{gen-set} all have fungicide added to the fuel for stabilization.Cost? starts at $2.85 gal.Jy
/ Premium Diesel... ? #27
Okay, I'll chime in here. I used to be in the fuel delivery business. I ran a tugboat that pushed a 145,000 barrel barge - that's a little over 6 million gallons. There are several different blends of diesel fuel depending on which refinery blends it. The premium diesel (also referred to in some areas as marine diesel) has additives added to boost both the cetane and the lubricity. Premium diesel came about due to the poor lubricity found in the new low sulfur blends. Seems there were some fuel pump issues with certain engines. Again, the base starts off the same more or less as everyone elses product, but the additives are added by each individual refinery. This is sometimes done at the refineries, and sometimes done at the tank.
This is what I've been told. I know the company where I work now, has a fleet of 17 vessels. There are two which we fill with 'premium' diesel and the rest get the regular stuff. Again, this is mainly a lubricity issue. We use millions of gallons a year, so I'm sure the owner is up to speed on the product. I doubt he'd toss away money for nothing. In fact, we have a regular fuel analysis program for each vessel to make sure what we get is up to our company's standards.
Doubt it makes a difference in a kubota. These are very high horsepower engines with an extreme duty cycle that see thousands of hours each year.
/ Premium Diesel... ? #29
I have operated various diesel cars and trucks on the road. Most of the time I bought fuel at a truck stop.I used Marvel Mystery oil added to the fuel. I have never had a fuel pump issue on any of my engines. I felt it helped lubricate the fuel pump and the valves and was much cheaper than a chance of repairs. My Kubota has it in the fuel now too. It only takes a few ounces to a tank. Jy.
/ Premium Diesel... ? #30
They problem with that plan is, when adding Marvel Mystery oil to ULSD fuel, it reacts with the additives in the fuel, and actually lowers the lubricity. :thumbsup:
This information is available on the web. It was proven in a study done by an independent testing lab.
The study is cited in many threads on fuel additives, here on TBN.
They tested many popular fuel additives, and found many needed to be reformulated for ULSD.
I do not know if MMO has been reformulated due to this yet.
If your additives do not specifically say something like: "ULSD Compliant", or ULSD Formulated", you should stop using them.
Sometimes good intentions are your worst enemy.
/ Premium Diesel... ? #31
Okay, if true, then I need to check the pump to see if I am buying ULSD fuel? Soon,I shall look at the Marvel container to find out if it is compliant. Thanks, for the warning! Being old school, I don't see how ADDiNG OIL can make something lubricate less? Yes, I like reading this site so that I can find out about different opinions, and options.At any rate ,I will check on it before adding any more to my tank.jy. OO-
/ Premium Diesel... ? #32
I am told high sulfur is still available, at least here, for off road.
But, I can't buy it around in this area at the pump. I would have to order a truck load.
Oil additives, and fuel additives have gotten very complicated.
Just like drugs can interact and produce unintended, and even opposite results, additives can do the same thing.
/ Premium Diesel... ? #33
Off road use still allows the regular sulfur fuel, Our company can buy it for standby gen-sets, and it is cheaper. Some fuel pumps have the very latest cut in fuel, which is very low sulfur. The Kroger pump that I have been using lately does not have a label I have seen. So that makes three different forms of Diesel here , I don't qualify for Farm Fuel, and have no idea about the compositon of it?I have used PowerService in the winter for gelling.
/ Premium Diesel... ? #34
What is farm fuel?
/ Premium Diesel... ? #35
Farm fuel can be high sulfur, or ULSD depending on what they order.
I add a small amount of this in off road ULSD, for insurance: Diesel Fuel Improver It scored very high in the study.
/ Premium Diesel... ? #36
The main difference in Farm Fuel here is the road TAXES, or at least a lot different. Supposed to be put in special marked storage tanks, and it has Dye in it. Big problems if you have it in a road unit. jy.
/ Premium Diesel... ? #37
Oh, So you meant Off Road.
Why don't you qualify for Off Road fuel?
2017 Link-Belt 350X4 Hydraulic Excavator (A64553)
2017 Link-Belt...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2008 Allmand...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2019 Dodge Charger Sedan (A64557)
2019 Dodge Charger...
2017 Ford Explorer SUV (A64557)
2017 Ford Explorer...
