PowerTrac Cold Weather Heaters....
/ PowerTrac Cold Weather Heaters.... #61
I have a remote switch that I can activate from my iPhone. I have the heater plugged into it. At 3pm I remotely turned on the heater. I got home at 6pm. 18 degrees in the barn. Choke left wide open. Hit the key and she fired right up. Couldn't be happier with the heater.
/ PowerTrac Cold Weather Heaters.... #62
Do you have anymore info on that switch ?
/ PowerTrac Cold Weather Heaters.... #63
I use the one made by ismartalarm.com. Its a smart switch. I also use their alarm for my barn. Works nice
/ PowerTrac Cold Weather Heaters.... #64
As long as there isnt debris as leaves and grass inside the cooling fins we've run the kholers in 95 deg heat all day long. The suburu we had to install 2 fans to suck and push the heat out from the engine compartment. It gets finicky when hot. Or just won't run, customers look at us a bit weird when one guy walks behind the loader with a large leaf blower blowing fresh air into the cooling fins just to get the job done. We really need a transplant kholer option, like years ago!!
/ PowerTrac Cold Weather Heaters.... #65
As long as there isnt debris as leaves and grass inside the cooling fins we've run the kholers in 95 deg heat all day long. The suburu we had to install 2 fans to suck and push the heat out from the engine compartment. It gets finicky when hot, even mid 80's. Or just won't run, customers look at us a bit weird when one guy walks behind the loader with a large leaf blower blowing fresh air into the cooling fins just to get the job done. We really need a transplant kholer option, like years ago!!
/ PowerTrac Cold Weather Heaters.... #66
3 hours and ready to go, that's what I wanted to hear!
These Robin engines cannot tolerate the heat in the PT tub. I'm convinced heat is the reason my engine is getting a major overhaul. Another fan, relocating fuel pump and better insulated exhaust will be done whenever I finally get my PT back.
New/Unused Wolverine 44in Mini Grapple Bucket (A65583)
New/Unused...
Glencoe 20' Field Cultivator (A66408)
Glencoe 20' Field...
Oliver 1800 Tractor (A66285)
Oliver 1800...
2015 Hitachi ZX75US Midi Excavator (A64553)
2015 Hitachi...
2022 EZ-GO ELITE...
INTERNATIONAL 700 SERIES 6 BOTTOM PLOW (A64278)
INTERNATIONAL 700...
