Powersteering Pulley
/ Powersteering Pulley #1
bjr
Eastern WA
Jinma JM354
I need a wider and smaller in diameter pulley for a '72 Ford Pickup power steering pump. The pulley I have now is a 5-3/4" diameter and takes a small 7/16" belt. I would like to go to 4-1/2 diameter and a 5/8" wide belt. Without going into a lot of detailed explanation I've got a retro fit a case tractor with the ford pump with the press on pulley and have pulley belt width issues. I've searched for offroad type aftermarket. Anyone got a handle on wider pulleys for ford presson type pumps? I need a wider belt to fit the water pump and crankshaft pulleys and make everything turn. bjr
/ Powersteering Pulley #2
I would think a parts house like NAPA should be able to fix you up. Good luck.
/ Powersteering Pulley #3
Worst case would be having a machine shop turn one for you.It still should be fairly inexpensive.
/ Powersteering Pulley #4
I was just in Tractor Supply the other day and noticed they had quite a selection of pulleys over near the electric motors and stuff. Not with the lawn mower parts.
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
2017 DRAGON 150BBL ALUMINUM VACUUM TRAILER (A63569)
2017 DRAGON 150BBL...
2017 CATERPILLAR 980M WHEEL LOADER (A64279)
2017 CATERPILLAR...
INFO LOT (A64047)
INFO LOT (A64047)
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
