Powersteering Pulley
/ Powersteering Pulley #1
bjr
Veteran Member
Eastern WA
Jinma JM354
I need a wider and smaller in diameter pulley for a '72 Ford Pickup power steering pump. The pulley I have now is a 5-3/4" diameter and takes a small 7/16" belt. I would like to go to 4-1/2 diameter and a 5/8" wide belt. Without going into a lot of detailed explanation I've got a retro fit a case tractor with the ford pump with the press on pulley and have pulley belt width issues. I've searched for offroad type aftermarket. Anyone got a handle on wider pulleys for ford presson type pumps? I need a wider belt to fit the water pump and crankshaft pulleys and make everything turn. bjr
/ Powersteering Pulley #2
I would think a parts house like NAPA should be able to fix you up. Good luck.
/ Powersteering Pulley #3
Worst case would be having a machine shop turn one for you.It still should be fairly inexpensive.
/ Powersteering Pulley #4
I was just in Tractor Supply the other day and noticed they had quite a selection of pulleys over near the electric motors and stuff. Not with the lawn mower parts.
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2023 Star EV Lithium Battery BI/Charger (A64912)
2023 Star EV...
THERM DYNAMICS TD 375 FLAMELESS HEATER TRAILER (INOPERABLE) (A67714)
THERM DYNAMICS TD...
2015 CATERPILLAR AP1000F ASPHALT PAVER (A65056)
2015 CATERPILLAR...
Shop Tool Box (A64912)
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
