Powered rake
/ Powered rake #1
Cletrac
Western MA
Kioti DK-45
Any one attempted to build a powered rake? I figure a small car rear end with the spider gears blocked, a couple of sprockets driving a drum with teeth set at an angle all mounted to a suitable frame, a PTO shaft to make it all go around and you have it! (more or less)
Thanks
Dave
/ Powered rake #2
I was thinking of doing the same thing, But we have a large Sweepster 3 point broom that is at the landfill we run. I can buy it for 300 dollars I may go from there it has 2 telescoopic shafts for angling the drum for the teeth and the gear box and 3 point mount. I know a fella down the road that has some weld on carbide shanks and teeth from a road planer i can get for a song.
/ Powered rake #3
If I could find a rototiller with a bent shaft or worn out teeth, I'd buy it to make a power rake. I might (someday) bite the bullet and buy a gearbox and just fab the whole thing............
As much as the factory ones cost, no way can I afford to buy one--unless I could get a long term contract with a builder to do all his lots. Most of them have implements they can attach to their bobcats and work the finish ground, so I doubt I could compete.
Post pics if you build one please.
Ron
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
Deutz D3006 Tractor (A62613)
Deutz D3006...
White 6182 12R Planter (A66285)
White 6182 12R...
2017 Versatile 260 (A64126)
2017 Versatile 260...
2716SFL (A61567)
2716SFL (A61567)
Femact 9 70REV Excavator Mulcher (A66285)
Femact 9 70REV...
