Powered rake
/ Powered rake #1
Cletrac
Western MA
Kioti DK-45
Any one attempted to build a powered rake? I figure a small car rear end with the spider gears blocked, a couple of sprockets driving a drum with teeth set at an angle all mounted to a suitable frame, a PTO shaft to make it all go around and you have it! (more or less)
Thanks
Dave
/ Powered rake #2
I was thinking of doing the same thing, But we have a large Sweepster 3 point broom that is at the landfill we run. I can buy it for 300 dollars I may go from there it has 2 telescoopic shafts for angling the drum for the teeth and the gear box and 3 point mount. I know a fella down the road that has some weld on carbide shanks and teeth from a road planer i can get for a song.
/ Powered rake #3
If I could find a rototiller with a bent shaft or worn out teeth, I'd buy it to make a power rake. I might (someday) bite the bullet and buy a gearbox and just fab the whole thing............
As much as the factory ones cost, no way can I afford to buy one--unless I could get a long term contract with a builder to do all his lots. Most of them have implements they can attach to their bobcats and work the finish ground, so I doubt I could compete.
Post pics if you build one please.
Ron
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
Landhonor Quick Attach Rock Bucket (A66285)
Landhonor Quick...
2011 JOHN DEERE 672G MOTORGRADER (A63276)
2011 JOHN DEERE...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
2000 Ford Windstar Van (A61574)
2000 Ford Windstar...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
