Power Trac Winch Questions...
   / Power Trac Winch Questions...
Drawback, can't be operated from tractor seat. What is lightweight? How much hp can they produce? Not everyone has a hydraulic power unit but small gas motor vs 33 GPM at 2500 psi.
Perhaps you should look elsewhere. :)
   / Power Trac Winch Questions... #32
They weigh around 30 lbs, single line pull is 2500 lbs. I use it mainly for pulling out logs and the tractor if it gets stuck. The beauty is they work when your tractor doesn't and it does not tie up the tractor when logging (I like to use my swinging mini hoe, lifting boom, grapple, or large bucket when logging). I would consider mounting a hydraulic winch to the back of the tractor somehow.
You could make a mount for it and operate it from the operator's seat but you are then getting the negatives mentioned above. Also, the winch is stronger than the tractors holding capability so you are limiting your pulling ability when mounted to the tractor.
Just using rope and directional pulleys is an excellent option for pulling out logs. Use non-stretch rope made for pulling. It works well and is inexpensive. Portable Winch also sells self release directional pulleys which are great if you want to make multiple directional pulls in a single pull (to get around obstructions etc).
Ken
The self releasing ones look really useful for longer pulls around corners. Still looking.... :)
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
PICKUP TOOLBOX (A58214)
PICKUP TOOLBOX...
KOMATSU HM400-5 OFF ROAD WATER TRUCK (A60429)
KOMATSU HM400-5...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
