Power Trac Winch Questions...
   / Power Trac Winch Questions...
Drawback, can't be operated from tractor seat. What is lightweight? How much hp can they produce? Not everyone has a hydraulic power unit but small gas motor vs 33 GPM at 2500 psi.
Perhaps you should look elsewhere. :)
   / Power Trac Winch Questions... #32
They weigh around 30 lbs, single line pull is 2500 lbs. I use it mainly for pulling out logs and the tractor if it gets stuck. The beauty is they work when your tractor doesn't and it does not tie up the tractor when logging (I like to use my swinging mini hoe, lifting boom, grapple, or large bucket when logging). I would consider mounting a hydraulic winch to the back of the tractor somehow.
You could make a mount for it and operate it from the operator's seat but you are then getting the negatives mentioned above. Also, the winch is stronger than the tractors holding capability so you are limiting your pulling ability when mounted to the tractor.
Just using rope and directional pulleys is an excellent option for pulling out logs. Use non-stretch rope made for pulling. It works well and is inexpensive. Portable Winch also sells self release directional pulleys which are great if you want to make multiple directional pulls in a single pull (to get around obstructions etc).
Ken
The self releasing ones look really useful for longer pulls around corners. Still looking.... :)
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
RoGator RG1100C (A56438)
RoGator RG1100C...
Deere 331G (A53317)
Deere 331G (A53317)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
207272 (A52708)
207272 (A52708)
