woodlandfarms
Super Member
- Joined
- Jul 31, 2006
- Messages
- 6,155
- Location
- Los Angeles / SW Washington
- Tractor
- PowerTrac 1850, Kubota RTV x900
Deutz Engine Mount Rubber Part Number 4193086
It is a NAPA Gold 1551
For the 1445, which takes the same WIX 51759 (Napa 1759) suction filters, I've ordered the two possible gaskets, as the 3rd variant is an "L" shaped gasket designed to go outside of the filter, not for the PT filter base.I recently installed a WIX 51759 hydraulic filter on a 1430. It looks identical to the PT filter. The only issue is that the gasket shipped with it is too thick to fit in the base where the filters screws into. I reused the old gasket when I installed the filter.
I noticed the specs for the WIX filter list three gaskets. it ships with 15415. 15661 is a little thinner. The other gasket is much thinner. Does PT ship the 15661 with their filters? I may just order one and see if it fits.
Thanks,
Bill
I would start by searching with your Deutz model number, (F2L2011?) or just look on the filter that you have. The number is printed on one of the flanges. I suspect that you have a 1319257, but verify that. If you do have a 1319257, here are the cross references;Hi there, everyone.
I was wondering if anyone has a part number for the PT 1430 air filter?
$70/filter sounds about right. Three years ago, I think I bought two for $60 on eBay. Amazon has the original, for my tractor at $44 at the moment. As I wrote, I try to shop around as these are fairly pricey filters.Thanks for your reply, Peter!On the 1430 you can see how Power Trac fit there own custom piece onto the intake to mount this air filter. My guess is they done this for less space. One time PT sent me my package inside a box with the name of who they get their air filters from. I looked it up and the filters were much cheaper, but you had to buy at least 100 ( or close to that number). I actually forgot the name of that company.
Just recently I bought a few air filters for the 1430 from PT, and they are $72 a piece.
The school I went to told us that blowing out an air filter with an air hose creates larger openings in your filter element, therefore, allowing more dirt to pass through your filter. It’s “Some food for thought.”
I need replacements for the rear two wheels, hence the smaller size.? I thought the OEM brush cutter wheels were bigger than that?
I understand that High Grade Mfg sells most of the laminated wheels to the OEM brush cutter mfgs. Recently bought 15" wheels and hubs from them to convert my OEM PT1445 brush cutter wheels. Quality seems fine, but am having to fabricate a different mount for the rear wheels on the mower deck. Will be posting more about that as I go along.
Quality Finish Mower Wheels | High Grade Manufacturing
Discover top-quality finish mower wheels. Our products offer durability and reliability, providing optimal performance for your commercial & industrial needs.highgrademfg.com
