Power Trac leaf blower
/ Power Trac leaf blower #1
jfh28
Platinum Member
Poconos, PA
Power Trac 2425
I don't know why I didn't think of this years ago......just used some bungee cord to strap on a piece of plywood on the pallet forks then strapped on a gas leaf blower.....the pallet forks will raise and lower as well as tilt and side to side can be accomplished by turning the steering wheel......simple, cheap and effective but does look a little amateurish :laughing: ....ultimate solution would be to attach a seat to the snow plow which has the six way function .......Jack
here's the blower in action
/ Power Trac leaf blower #3
Great minds think alike ! Had to improvise while the flat tire on my zero turn was getting fixed !
I agree :thumbsup: ......Jack
/ Power Trac leaf blower #12
Very nice. I really wish PT would make a leaf-vac attachment. Seems like it wouldn稚 be too difficult. Maybe I will make my own one of these days.
/ Power Trac leaf blower #13
Sounds like a great idea. If you find a good source for a fan, let us know.
All the best,
Peter
/ Power Trac leaf blower #14
I have a tow-behind Rubbermaid cart. I've been contemplating finding an old Snapper 28" ish round mower deck and suspending it under the cart, and powering it with a hydraulic mower. Those little Snappers were great for picking up leaves. They blow almost straight up, so all I'd need to do is put a hose in it and run it straight up to a canvas bag-topper for the Rubbermaid cart with a 1X3 frame for support for the bag. Someday.... :rolleyes:
/ Power Trac leaf blower #15
Sign me up, id buy one as well. Going to go at it myself this spring (buying a cyclone rake). I lined most of my finish mower deck with a rubber skirt. I'm thinking i will notch out space for a regular lawn tractor adapter, mount it up and give it a try. Based on the spitting of leaves this fall I think the best spot to suck from is the back left or front right.
IF / when I get it all rigged up I will take some pictures and report back.
/ Power Trac leaf blower #16
Awesome! Will be awaiting your report :)
2006 FORD F-450 SUPER DUTY SERVICE BED (A67714)
2006 FORD F-450...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2022 Mack Anthem...
2014 Crane Carrier Co. Low Entry T/A Rear Loader Garbage Truck (A66736)
2014 Crane Carrier...
2015 FREIGHTLINER CORONADO 122 SD (A67714)
2015 FREIGHTLINER...
