Power Trac and grass cutting
   / Power Trac and grass cutting #21
<font color="red"> Plumsteadville?? </font>
I dunno. Hans once told me
<font color="blue"> Buck's County
8 Mi NW of Doylestown
8 Mi SE of New Hope
</font>
   / Power Trac and grass cutting #22
In general and within reason, you will find far more times when you will be glad you went bigger than times when you wished you went smaller.
That said, $$ obviously are a significant part of the equasion, but perhaps you can "hold off" on an accessory or two with your initial purchase in order to be able to get the larger basic machine.
It seems that most folks with the 425 are satisfied with their overall capability and only a few feel they need to upgrade into the diesel series, whereas there seems to be more owners of the smaller units seeking to step up to the 425 after a year or two.
The 425 seems to be the "sweet spot" for most folks. I have the 1845 due to some unique requirements on my mountain property.
Good luck with what ever you choose!
Rip
   / Power Trac and grass cutting #23
And no one is mad at their 422's, either, from what I've heard. /forums/images/graemlins/wink.gif
   / Power Trac and grass cutting #24
I was not trying to imply that folks were "Mad" or dissatisfied with either the 180 or the 422, just that a higher percentage perhaps wished for something a bit bigger and more powerful and able to handle a wider range and/or size of attachments.
Seems like a bigger step from the 180 to the 422 than from the 422 to the 425. Am I right?
I am sure that for a good number of folks the 180 (or 422) may well be just the ticket and already "bigger" than what they previously had or were otherwise considering.
Rip
   / Power Trac and grass cutting #25
I agree.
I was just trying to beat the 422 owners to the punch before they remind me that my model year 425 is basically the same as the 422s and 418s, just a differnet engine.. For a while, I would always bring up the fact that I had the bigger engine. The 422 guys would remind me that they were very happy with their 422s and thought the HP/Torque numbers were deceiving, because they weren't measured in the same manner.
Today, I could throw in the different wheel motors and higher lift capacity as major differences, too, but back then, I had to eat crow. /forums/images/graemlins/tongue.gif
<font color="blue"> Seems like a bigger step from the 180 to the 422 than from the 422 to the 425. Am I right? </font>
From reading the Power Trac website, I would agree. /forums/images/graemlins/laugh.gif
   / Power Trac and grass cutting #26
I would suggest that if you have steep hills to mow the 425 would probably be the best choice. My 422 does fine for most mowing but I also have some hills up to near 30 degrees slope to mow. Mowing downhill works fine but to try to mow uphill it just does not have the power to run the mower and climb the hill, and mowing across the slope feels a little on the steep side.
   / Power Trac and grass cutting #27
Farmall140 . . . I considered, but did not buy a PT machine and instead opted for a Ventrac. My big concern was mowing hills. I would NOT recommend a Ventrac for you becuase it simply won't do what you NEED to do, but based on what I was able to find, if you have some steep spots, then I think you should dismiss the PT180. You might even want to dismiss the PT422 based on some comments I've read about low power to the deck while going UP the hills.
I honestly think the PT tractors are amazing units, but if your hills are steep, then the PT425 is probably the better choice for you because the new units have higher wheel torque motors and those should get you up the hills with minimal effort, the extra 3 hp may not seem like much, but that will also be put to good use spinning your mower blades on the uphill climbs.
As I searched for my new tractor I found out a lot about Power Trac units and while I am not an owner of one, I am sure that they are simply better tractors than most. Quirky and proprietary, but excellent machines capable of doing what needs to be done, often better, faster and safer than other machines. I would hate to see you get a machine that won't quite, or maybe just barely does, what you need to do and have you overwork it and prematurely wear it out or find out you should have gone up 1 more size, only to end up disliking the machine that might be your best choice if you had only gotten the right unit.
<font color="blue"> </font> Well..just want to thank all of you for your input and as usual the more I look into a major purchase the more complicated the decision making process becomes! It will probably be a month or so until i take the plunge..and am leaning toward the 422...would rather the 425 but just can't afford that and my daughter's wedding this year too!!!(Man...are weddings expensive!)....going to see if I can make the trip to see a PT in action from those that have offered to give me a demo...since this time of the year I tend to travel a bit I'm gonna try and co-ordinate work/pleasure sometime in the near future.....won't be too long though..already have pushed the mower over 2 acres one evening..and that gets old fast!
   / Power Trac and grass cutting #29
You could push the elope angle! /forums/images/graemlins/tongue.gif
   / Power Trac and grass cutting #30
"" didn't have any problems with overheating. ""
/forums/images/graemlins/confused.gif It depends upon your definition of overheating!! /forums/images/graemlins/confused.gif
With my new PT-425 after 3 hours of PTO use, with the hydraulic oil cooler fan running, the Hydraulic Oil temperature in the hydraulic tank was 180° F. at an ambient temperature of 60° F.!!
Per ( www.precisionfluidpower.com/oil_recommendations.htm ) : ""Hydraulic Oil operating temperature should not exceed 200° F. with a maximum of 180° F. generally recommended. 120° F to 140° F. is generally considered the optimum system operating temperature. High temperatures result in rapid oil deterioration and may point out a need for an oil cooler or a larger reservoir. The nearer to optimum temperature, the longer the service life of the oil and the hydraulic components."" /forums/images/graemlins/blush.gif
Continuing to operate a hydraulic system when the fluid is over-temperature is similar to operating an internal combustion engine with high coolant temperature. Damage is guaranteed. Therefore, whenever a hydraulic system starts to overheat, shut it down, identify the cause, and fix it.
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
Zero Turn Mower (A59231)
Zero Turn Mower...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
2010 Kaufman Gooseneck Trailer (A59814)
2010 Kaufman...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
