Power steering loosing power
/ Power steering loosing power
Bigpete and Del,
I doubt if they have checked the tire pressure. If I blew 40 psi in the front tires it would certainly make steering easier. As it is I keep tire pressures pretty low (15 - 20 psi) so as to spread the weight out as evenly as possible on my lawn. I have noticed that the steering behaves the same on both concrete, dirt and gravel.
Getting the correct ballast is a easy as parking my fat **** on the box blade. Doing this makes the steering problem disappear, until someone with a similarly fat **** stands in the bucket. Remember, the capacity of the bucket is 781# at the lip so with three fat asses in the bucket it won't steer at all.
The tire issue is a little tougher for me. I sold the stock turfs on eBay. The oversize turfs are mounted on the stock rims and are just about the same diameter as stock R4s. The dealer has no correct size turfs but there is a used 4100 with stock R4s that I might be able to borrow. I am not sure if the dealer would let me do a temporary swap but I'll bet a buck the RM would claim that the used tires "are not within the design specifications". But you may be right, I may have to do some back flips to get them to diagnose and fix the problem.
What really irks me is the simple fact that my turfs have absolutely no cause or effect on this problem. The RM has little to no mechanical knowledge and seems to be just another bureaucrat from hell more interested in the rules than the problem. I really expected better from JD.
At this point in time I am pretty discouraged and am trying to think of a way to rid myself of this tractor. I won't sell it without disclosing the problem and no one is likey to buy it with the problem. On top of that, I still prefer this model to any of the others; orange, blue or green.
So I am going to wait until next week to hear from the RM or dealer. If I don't hear something by Tuesday I will make another call to the CCC. Thanks to all for the suggestions and encouragement.
Kyle,
You are correct about the 4WD. In another thread we discussed the 4WD ratio problem. With these bigger tires the rears are probably pushing the fronts in 4WD. There is an acceptable range of 4WD ratios but I don't know what it is. At some point I calculated the stock and my ratios using the tire circumferences but I don't remember them at the moment. I only use 4WD when I get stuck. If I used 4WD frequently on surfaces with good traction I expect I could cause some damage, but I don't see where it would cause this steering problem, especially considering how rarely I use 4WD.
If I keep the tractor I will probably research the 4WD ratio issue and then get front tires that will put me in that range. However, I won't return to stock size turfs as the tractor is significantly less useful with them because of the lack ground clearance with the MMM. Fully raised, the MMM banged on the ground whenever I crossed even the shallowest depression. Crossing a ditch was impossible, cutting one even more difficult.
Had I actually seen a 4110 fitted with turfs (at the correct pressue) and the MMM I would never have bought it so equiped. When I picked up the tractor the MMM was not fitted and the rear turfs had 40 psi in them. They looked like something in a cartoon. By the time I got them down to the correct pressue the MMM was practically on the ground. I guess I should have just returned it to the dealer at that point but I figured I was smart enough to fix it myself. At my age I should know better.
/ Power steering loosing power #43
But JClark, I gotta' ask again....
Have you checked your steering function with a set of stock tires back on it? Or...
Did the steering problem start when you put bigger tires on it? and...
Did your dealer sell you and install the bigger tires?
I, too, just learned from your recent post that you were running bigger tires. As I said, I doubt that is your problem. However, if you don't debunk the RMs diagnosis you won't get anywhere with Deere.
FWIW, I drop my belly mower on most all ground work anyway, so it doesn't matter that it's not sucked up to the floorboards. Always did it on my brother's 855, too. The clearance on the bigger tractors with belly mowers typically isn't enough for heavy work either. catch the corner of your deck on a stump or a rock once and your suspension can be trashed...even with 16 inches of clearance.
Good luck
Bigpete,
I changed to the bigger rear tires when I had about 10 hours on the tractor. I consulted with the dealer before doing it, specifically asking if it would affect the warranty and he assured me it would not. The steering trouble showed up at about 63 hours, after I changed the hydraulic fluid. The dealer did not supply the tires and could not mount them as they have no tire equipment. As this time there are no stock turfs available for me to try. My only option is a used 4100 with R4s and I have not asked the dealer if I could mount them on my tractor.
My MMM clearance made it a problem just to go down the lane and cut my other lot. Also I could not cross much less cut any swales or ditches with out the mower scalping baldly. The extra clearance of the bigger turfs lets me raise the MMM enought to cut my ditches and swales.
If JD insists that a turf tire with a nearly identical diameter as their stock R4 is causing this steering problem then there is a problem here bigger than my lack of steering. That kind of customer disservice will not benefit them very long. Much as liked my past JD products, I would not recommend one to anyone now. That said, you are probably correct - JD won't do squat until the tractor is configured to their exact specs. I do expect they will remember my name by the time this is over though.
/ Power steering loosing power #45
Well, good luck JC. I've been hoping that they would figure this out by now. Earlier in this thread and in a couple of others I have written about my GOOD experience going through the JD Customer Complaint Center. Every time I hit a road block on my problem, they were there to help get things escalated. I think you said you had a case number already. My case ended up being turned ino a trade up to a 4110 at a reasonable cost. Maybe you can get your problem resoved by telling them you have exhaused all avenues with the dealer. I still would guess they won't do anything until the tractor is back to "stock," but that beats suffering with a poor performing tractor. Does the tire dealer still have your stock tires and wheels around?
Get back on the phone and keep us posted. /forums/images/graemlins/wink.gif
/ Power steering loosing power #46
<font color="blue"> The steering trouble showed up at about 63 hours, after I changed the hydraulic fluid. </font>
How many hours have you put on since the fluid change? You could simply have air in the system causing the loss in steering power. What happens is an air pocket is created in the steering cylinder and when the fluid is diverted into the cylinder the air compresses and little movement is the result.
Trapped air in the steering cylinder would require you to turn the wheel lock-to-lock at least 10-15 times holding the wheel at each lock position for a few seconds to activate the relief valve. This should be enough to clear any trapped air(although it could take more). As you do it you should start to feel the power increasing each time. Sometimes you can get a stuborn air pocket that takes a while to get out. Hope this helps.
/ Power steering loosing power #47
I wouldn't think the cylinder would drain out during an oil
change but I suppose it's possible.
I replaced some loader hoses on my older tractor and for some
reason the air that entered REFUSED to leave for quite a
lot cycles. Guess it felt comfortable in there!
Sometimes a solution to a problem is the easiest goofiest
thing to fix! Let's hope so. From what the gentleman has
discussed so far I don't know if the dealer has cycled it
a bunch of times to check it. Cars and trucks are like this
too if the system gets air in it, GM says to raise the front
of the truck off the ground and then cycle it left and right
multiple times letting it stay (gently) on the L and R stops
for a couple of seconds.
/forums/images/graemlins/smile.gif<font color="blue">D</font><font color="orange">E</font> <font color="green">L</font>/forums/images/graemlins/smile.gif
/ Power steering loosing power #48
It's not that it would drain but rather air in the system makes its way to the cylinder and then it just sits there so you're left with a compressable pocket of air(a bad thing). Now the hard part is getting it out because it is trapped in the end of the circuit(so to speak). That's why sometimes it takes quites a few cycles to get trapped out of the steering circuit. And to be honest testing the system isn't a big deal. You have the the steering valve, a priority valve, and the steering cylinder. Pressure and flow checks along the system should reveal any problems. Any service shop should at least have a pressure gauge with assorted fitings to do pressure checks. I would even say they should have a flow meter, heck I have one! My gut still thinks air in the system.
/ Power steering loosing power #49
jrlichina,
I was thinking that when you drain the system you are only
draining the unpressurized tank, that the hydraulic pump
wouldn't even drain out. But thinking about it after your
post if the pickup tube gets air, then air will be in the
pump and air will end up just about anywhere in the system.
If the fluid has bubbles it can be compressed, and although
the steering would operate normally under no-load, the
added load of the bucket off the ground may make air more
of a factor.
I am barely fumbling my way around hydraulic systems, but I
would think a tractor dealer would already know all this stuff.
Of course even the pro's get caught by simple stuff. I once
looked at car that had some multi-hundred dollar "dyno-tune"
by a speed shop.
I added about 50hp?/forums/images/graemlins/shocked.gif in about 3 minutes. They hadn't bothered
to see that the throttle was wide open when the gas pedal
was depressed!
I never told the car owner what I did, he thinks I am a GENIUS!
Nice to have at least ONE person think that!/forums/images/graemlins/wink.gif
Jrlichina
Thanks for the suggestion. Heading out the door right now to try it.
Dang - no luck. I cycled it about a dozen times, pausing for a few seconds at each lock. Sure does steer easy with the wheels hanging in the air though.
Question: should the steering wheel continue to turn past the lock? As I was holding just a little pressure at each lock the steering wheel would continue to turn.
/ Power steering loosing power #52
At this point, I'm kinda hoping its not something so simple. Too many folks in the loop on this one! Tough clam ta swallow.
This needs to get resolved! /forums/images/graemlins/grin.gif
/ Power steering loosing power #53
No luck, rats. Well they are going to have to check out the system doing pressure and flow checks. That's the only way to find out if there is an obstruction or malfunctioning part in the system. They should be looking specifically at the power steering pump since your tractor has a tandem pump(one for steering and one for implements). Then the priority valve then the steering cylinder.
Update:
Over a week has passed since the visit from my dealer and the regional manager and no word from either. (Surprise, surprise.) I made another call to CCC and left a message with my advisor.
Attached is a picture of the tractor in my test setup.
For ballast there is:
Frontier BB1060 box blade 495#
4 suit case weights 168#
2 channel iron 84#
Total ballast 747#
Load in FEL:
Barrel 39#
Chain 8#
5.4 cubic ft water 340#
Total load 387#
Note the non-stock rear tires. They are 33.5" tall. Parked where you see it, with me in the seat, engine running at 2000 rpm, I can turn the steering wheel about a half turn in either direction before I feel a lot of resistance at the steering wheel. With some effort I can turn about another quarter turn of the steering wheel. The engine does not slow or labor at all when I attempt to continue turning.
The rated capacity of the loader at the lip of the bucket raised 59" is 781#, so I am at about half load. Recommended ballast is 750#, so I am a few pounds shy of that.
So is it the connection between the seat and the steering wheel, or is something else not right?
/ Power steering loosing power #55
Your front tires look a little on the low side for air pressure, what are you running them at? That tractor should steering with little to no effort with that load even if the tires were a bit low. Have you tried another tractor at the dealer to compare yours with? I still think there is a problem in the steering system. My BX2200 with 500 lbs. in the loader an NO ballast turns with ease with one hand(heck even a few fingers will do it).
/ Power steering loosing power #56
Yikes /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/crazy.gif
A BX with 500# in the loader and no ballast might become a two-wheeler pretty quickly!
/ Power steering loosing power #57
I think it is ridiculous that they suggest taller tires are causing the problem. If that is the case, then every time you go down a slight incline the power steering would fail. It sounds as if your problem is either a bad relief valve or something leaking internally in the system. You mentioned that the steering wheel would keep turning at extreme right and left turns. How much did it turn? How much pressure were you applying to the wheel? There is a spec on the amount of allowable turning at the stops. I am guessing something like 5 turns per minute with 60 inch pounds of force with the oil hot. If it exceeds that, you are bypassing oil in the cylinder or the valve. I hope this helps.
/ Power steering loosing power #58
JD 110 Good point on the slope perspective. No matter WHAT
ballast you have on the back you can easily get the tractor
snout down doing something. I know I have with a load in the
bucket.
And another point, the power steering shouldn't fail with
a load in the bucket anyway. One of the Kubota brochures
shows a small Kubota with a load of firewood in the bucket
and a trailer full of firewood behind it.
Tongue weight maximum on the drawbar is fairly light so
that is only going to be a small part of lifting weight
off the front.
The tires in his pic DO look low though.
I've always thought the maximum pressure should be used if
a loader is going to have anything in it.
Will be interesting to see what they come up with.
/ Power steering loosing power #59
Early last summer I used my 4210/420FEL to spread road gravel on my drive, filling the bucket full enough to make the rear end light (no weights or implements on the back) and I could still easily steer lock to lock at 1200 rpm sitting still.
Something has to be wrong with your JD, and in my opinion a problem also exists in the pea sized brains of the SM and RM. With all the buck passing and wasted time they would have been WAY ahead replacing the steering pump to learn if that is the cause. Jeez.....
/ Power steering loosing power #60
Since the JD steering system is entirely hydraulic and when (in your experiement) you met resistance, there are only two choices. Insufficient hydraulic pressure or mechanical binding in the steering hardware. If it was mechanical binding the hydraulic pressure would build and strain the motor. You have a hydraulic problem. The difference in the larger rear tires could only be considered a problem when your moving with 4 wheel drive on but even then you should see some engine lugging. The tire size difference could cause a problem, but it won't be in steering.
