Power steering loosing power
/ Power steering loosing power
BillyP
"the service guys are clueless"
I think you hit the nail on the head there. As I mentioned upthread, they don't even have the equipment to test the power steering control valve.
Made the call this morning (they were closed yesterday). The menu choices were only for sales information so I took the first one I could (Scotts equipment sales) and asked the woman for a number to call for my problem. She asked for some specifics on the dealer, the tractor and the events and then gave me a case number. She was very helpful and professional and it seemed as if she had done this many times before.
/ Power steering loosing power #22
You dialed the right number. I've forgotten the sequence, but you have to navigate your way to the C.C.C.. Don't forget to jot down the name of the person who helped you. When working my way through my problems, it was good to have one person familiar with my situation and what I was going through. That way I didn't have to re-explain the problems and the past steps every time I called.
Good luck. Too bad you have apparently run into incompetency. On the other hand, I hope that is all it is so they can fix it quickly and get it back to you rather than you have to deal with a replacement or rebuild. I'm following your story as I wait for my 4110 (replacing my leaking 2210) to come together at my dealer after a month of waiting /forums/images/graemlins/frown.gif
/ Power steering loosing power #23
I can't find my JD sales brochure so I don't know if that
has a separate pump for the steering. If it does, it
shouldn't matter what you do with the bucket, the steering
should basically stay the same unless the tractor is low
on fluid.
If it has only a combined pump, then yes operating the loader
will affect the steering, just as it slows down operations
on most tractors when you raise and dump the bucket at the
same time etc.
Once the load is at the height you want it the steering should
return to normal with only one pump. The tractor will of course
act differently with or without a loaded bucket.
You know how it did act. Have you just hopped on another
tractor on their lot to see if it's the same? That's a good
test.
I found it funny the dealer would pull the front end off the
ground and say if the wheels turn lock to lock everything is
OK. A tractor with NO kind of power steering will do that!
I have a current Kubota and a JD, both of those
with their separate steering pumps don't even seem to care
if the bucket is empty or not.
You might have to go to some other dealers but try a couple
other new units out and you'll know if they are pulling your
tail, (or trying to). Or maybe they honestly don't know
what's what.
I recently went through the same thing with a vibration on a
vehicle. Dealer (under warranty) said it's "normal" they drove
another that did same thing. Lived with it then decided it
was going to be fixed or I was going to make GM my life's project.
Second dealer checked everything out, including a couple of
things dumb old me suggested, vibration is gone. I had driven
another one that was vibration free, so I knew it was not "normal"
Good luck with it. Be patient but as the other fellow said, the
next step is up the ladder at JD.
/forums/images/graemlins/smile.gif<font color="blue">D</font><font color="orange">E</font> <font color="green">L</font>/forums/images/graemlins/smile.gif
/ Power steering loosing power #24
Is the service guy working with the tech people at JD on this?
My dealer had a problem with my JD predelivery and although he
has commented JD's ordering system and website are his biggest
pains, said his experience with the tech-heads (a compliment)
at JD have been fantastic, that they kept going at it until
the problem was resolved.
As I mentioned in my other post, I'd be curious how you felt
about the steering on another tractor/same model/same trans.
And you're right, as long as the tractor didn't break in
half you'd be able to steer easier with weight "way out back".
I think that's how the old timers had power steering with those
big farm tractors!
On my older Ford, that doesn't have a separate pump I find I
can assist the power steering greatly by using the turning
brakes. Early in it's life I just tried to turn the steering
wheel with a load of gravel, looked down and the R1's were
danged near squirming off the rims.
Pumping the turning brakes and using a lighter touch works
wonders.
Again, in your case it's not normal as YOU know there has been
a change. One of my previous ISP's always like to blame
connection problems on my "settings". OK, then why did it
work the last 3 months with the SAME SETTINGS?
Speaking of getting the run around, I know, a little off subject
but hoping you can use some humor. That ISP that I used in
1999? was bought by a larger company with "24 hour tech support"
only the problem was ALWAYS WITH YOUR COMPUTER NOT THEM.
I used to start the conversations off with, I have two different
computers, 2 different operating systems, 2 different modems
and am using lines to 2 different phone companies. (was true)
Sometimes then they'd help. The high point was when they
excused themselves to go "check system status" when I was complaining
of a problem. They came back and said everything is OK.
Turns out their main office in Tacoma Washington was BURNING
TO THE GROUND! Was about 2am and the guy didn't even know it.
Much easier to just say "everything's OK with us."
I always think of that when somebody tells me there is no problem.
/ Power steering loosing power #25
Del, that's a GREAT story ... but, unfortunately true in so many cases...
JackD
/ Power steering loosing power #26
Hi I am a john deere tech myself, and I was wondering if the service manger or the technican you have talked to have tryed looking up the problem on Dtac to see if there is any solutions on there? If any other techs have had problems with the steering loosing power. There may very well be a solution already on dtac if any other dealers in the USA have had the same problem with the 4110 loosing steering power. If you want I can go on Dtac and see if there is a solution myself. But I would think inless the service manger has his head up where the sun dont shine he would have already checked there.
Jonathan
/ Power steering loosing power #27
</font><font color="blue" class="small">( <font color="blue"> If you want I can go on Dtac and see if there is a solution myself. </font> )</font>
DTAC,
Can that be accessed online by anyone,or is that something for dealers only?
/ Power steering loosing power #28
Sorry dealers only, it is a private site that can not be found on search engines.
Jonathan
deere955
I think the service manager has talked to someone at JD but who that was I don't know. He is a young guy and seems to think I am just making this problem up.
The Regional Manager was supposed to come look at the tractor Monday morning (1/26) but never showed. Nobody called but I assume the 2" of snow we got held him up. So I wasted a morning waiting for him but still managed to get to my appointments that afternoon. Grrrr.
/ Power steering loosing power #30
I would go talk to your dealer and pull up DTAC for info. I had my service manager do that for me because no one could fix my loader and I followed the instructions he printed off and it worked.
Update:
The regional manager and the dealer came by this morning to look at the tractor. I started it and let it warm up a little and then did the demonstration routine - raise empty bucket of FEL, try to steer. Same as usual - can't turn steering wheel more than a half turn either way. The RM tries it, same thing.
RM: You have a couple problems here, first you don't have enough ballast, second, your rear tires aren't stock.
I have a 60" Frontier box blade with some suitcase weights on the 3pt hitch, total weight about 500#. The rear turfs are not stock, they are 3" taller and and 2" wider than stock.
Me: What difference do the tires make?
RM: They change the angle the tractor is sitting.
At this point the technical term "********" enters the conversation. After going back and forth for awhile we come to the bottom line: If they can't diagnose the problem I am SOL until I change back to stock tires and mount the specified amount of ballast.
The dealer's contribution to this exchange: "I am worried about getting paid for all the work I am doing on this tractor"
The RM is supposed to check with the service manager to make sure all the necessary tests have been performed and get back to me. Assuming he bothers to call at all, I am pretty sure I know what I will hear: "Everything checks out."
So now I wait again.
/ Power steering loosing power #32
I think your correct on the technical term used. If the machine was under load all the issues ballast tire size and whatever would change also depending on what you were doing I.E. using the FEL or box scraper. What a crock they come up with.! I would be embarrassed to say such things who do they think they are kidding
/ Power steering loosing power #33
It appears the RM knows about as much as the SM does which is pretty darn little. And you have to put up with the general incompetence, delays, and buck passing while they try to figure out another way to weasel out of a warranty issue. If I were in your place, I would be mad as hades about this. Wish there were something the rest of us JD owners could do except provide moral support.
/ Power steering loosing power #34
Were you able to try out a stock one yet? That should tell
a lot and go a long way towards rebuffing their comments. You
can then throw a stock set of tires on yours to alleviate
that "answer" as well.
I'm assuming the first thing they did was check the tire air
pressure. Normally there is a wide range of allowable settings
I think on the fronts on my 4210 it was 10psi for a loaderless
tractor with no front weights or front implement up to
35psi as a setting for loader use where you plan on actually
using the loader.
Tire pressure can make a big difference in contact patch and
resistance to steering.
And as I mentioned before, your tractor has two pumps one
dedicated to steering one for implements. If they actually
told you the "pump" singular is too small to do both jobs
I wouldn't bother talking to them anymore, and put the
comment about them not even knowing the BASIC information
about your tractor in your letter to JD.
Thought of you yesterday, went out to my K2500HD Chevy Truck
with 35K on it. Started it up, went to back out of the garage and WHEW,
NO Power Steering, NO Power Brakes.
Brakes and Steering were both there if you were able to
do a quick Incredible Hulk imitation.
Instead of a brake vacuum booster the brakes are tied into
the Power Steering System. What brainiac at GM thought of
that? Go GM, for hiring engineers with the common sense
of a bucket of spit.
Take away my steering or my brakes, but not both please...
The week before we had 9000lbs behind it!
Nice of the gal to poop out sitting in the garage!
/ Power steering loosing power #35
JClark...To try to help you, I called my dealer. (As I said before he is super) and he verified Del's comment that there are two pumps -- a 5.1 GPM for the hydraulics, and a 2.3 GPM for the steering, for a total flow of 7.4 (DUH!) Anyway, I guess by now your dealer has checked the steering flow, pump, etc. I'm wondering if any others here can talk to their dealers to try and get some kind of solution to your dilemma -- this is getting rediculous. I also found an "answer center" number (800-537-8233). BTW, my dealer used the same term for their technology that entered into your conversation with the RM!!!
Wish I could help further...
JackD
/ Power steering loosing power #36
Del.
Regarding your truck. Generally trucks 1 Ton(even some 3/4 Ton) or larger are fitted with hydraulic assisted brakes(GM known as Hydro-Boost) to give you better braking power. The source of the hydraulic power is from the power steering pump. A standard vacuum booster doesn't provide enough power to properly apply the brakes fully. Since you said your's was a K2500HD I'm assuming it has a diesel engine? If so that is also why you have hydro-boost. As you should know diesels do not generate engine vacuum due to a lack of a throttle plate. Diesels have a separate electric driven vacuum pump. So the engineers actually know what they are doing. I hope this helps.
/ Power steering loosing power #37
thanks jrlichina,
In this case its a 454 FI gas engine (3/4 ton). This setup may work
better than the vacuum but I hate the idea I can lose both
steering and brakes.
I guess I'll have to build up my muscles, and these tractors
aren't helping, they steer as easy a bicycle!
As I remember from the old pre FI days if you got near the carb on a 454 it would try to suck your arm in!/forums/images/graemlins/shocked.gif
/ Power steering loosing power #38
Hey, JClark.
I have been watching your thread based on the fact I am now a proud owner of a 4110 (with excellent steering response). Sorry for the disappointing meeting. It does seem that they are trying to dismiss the problem.
I have one question and one suggestion.
First, I know you have contacted JD's CCC. Have you let them know that you are not satisfied with the DM's findings?
Second, I would suggest that the only way to verify that the rear wheels have nothing to do with your problem is to have them put stock rear wheels on the unit and test the steering. As far as I can tell, you have not violated your warranty by using larger wheels. However, Troubleshooters (whether B.S.ers, or not) look for the simplest solution. In your case, I think it would be reasonably simple to validate (or debunk) the knee-jerk claim of the DM that your steering problem is caused by ballast and larger rear wheels.
Don't take this the wrong way, but if you put proper ballast and stock wheels back on the tractor and the problem goes away, you might want to think strongly about leaving them on. If the unit a'int big enough, I'd recommend the 4115 or 4310.
I think you have about as much chance of messing up your steering by putting on larger wheels as I have at playing in the NBA by putting lifts in my Converse tennies. Once the steering fails to work with the stock tires and ballast on the back, they will need to look for another (the real) problem.
JackD,
Thanks for the help and the phone number. In all my conversations with the dealer they never used the plural of pump. They have said several time that they "tested the pump". So you may be onto something here - they may not know there are two pumps. I do know they have not tested the power steering control valve because their senior mechanic told me they don't have the adapter to do it. I mentioned this to the RM but it did not seem to make much of an impression on him. So far I have not heard anything back from them.
/ Power steering loosing power #40
</font><font color="blue" class="small">( The rear turfs are not stock, they are 3" taller and and 2" wider than stock.
Me: What difference do the tires make? )</font>
I've been following this thread since the beginning and this is the 1st I've read about the non stock tires.
I may have a theory, please correct me if I'm wrong as I don't own a 4110. The brochure I have says 4WD is standard.
If your tractor is 4WD, and if you have different size tires on back other than spec'd out, something has to give somewhere. Either driveline, traction, or whatever. Could you have stressed the system which could be in some kind of bind causing difficulty in the steering? I would guess the rear drive is much stronger than the front. Otherwise, if you are driving without the 4WD switch turned on, you are taking a big chance that it won't get accidentally turned on by you or someone else.
However, If your tractor is 2WD, please ignore my theory and classify it with the aforementioned terminology.
Just a possibility, trying to help,
Keep us posted
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
Cattle Feeder (A65640)
2022 EZ-GO ELITE...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
Bobcat Turbo 873 Skid Steer (A62679)
Bobcat Turbo 873...
