Power Shuttle problems
/ Power Shuttle problems #1
scanderson
Massey Ferguson 1643
I have a 2014 1643 Massey Ferguson Power Shuttle. It suddenly just started going forward only even in the neutral position. When I go to reverse the tractor will stop like it's in neutral. The micro switches at the shifter check good. If I unplug the connecter at the solenoids at the valve the tractor will not go in any direction do guys have any idea?
/ Power Shuttle problems #2
I don‘t know that transmission, but are you sure there is no mechanical linkage to the transmission?
/ Power Shuttle problems #3
If you disconnect all (both) of the solenoids you could verify if you are getting a voltage signal to them at the proper times.
Also both solenoids should ohm out the same often 5-8 ohms for the windings.
2022 JOHN DEERE 17G EXCAVATOR (A63276)
2022 JOHN DEERE...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2022 Chevrolet Silverado 6500HD 4x4 Service Truck (A64194)
2022 Chevrolet...
ATS Power ATS-RT12R Mini Excavator (A66408)
ATS Power...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
