Power shuttle has no neutral?
/ Power shuttle has no neutral? #1
Rawbert
Naples, FL
1967 Case 580CK
1967 Case 580CK.
Power shuttle works forward and reverse, but can't seem to find the neutral position.. so the tractor goes either forward when I push the lever to the front or backwards when push it the other way, but no neutral in the middle.. there should be a neutral, right??
A couple of times I was able to find a lever position where the tractor stopped moving, but the lever slowly moves into reverse from the gravity..
How do I fix this?
Is the issue caused by some worn out spool seals/o-rings in the control valve box?
/ Power shuttle has no neutral? #2
All shuttle shifts I've been around have a neutral position between fwd. & rev. I'd suggest to thoroughly inspect the control linkage.
/ Power shuttle has no neutral? #3
I don't know about a 67 C/K, but on my 86 Super E with torque converter drive, the steering column shuttle shift lever is either in fwd or rev. The only neutral is on the 4 spd trans.
/ Power shuttle has no neutral? #4
Yep, no neutral on our 580L.
Closing Wheels (A65640)
Closing Wheels...
Bandit 200XP Wood Chipper (A63689)
Bandit 200XP Wood...
10' Rotary Hoe (A64126)
10' Rotary Hoe...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
2014 Bobcat T870 (A64126)
2014 Bobcat T870...
Wooden End Table (A64127)
Wooden End Table...
