Power shift stuck in 2
/ Power shift stuck in 2 #2
The 186 came with a column shift and floor shift, which do you have?
/ Power shift stuck in 2 #4
Not sure what you can see with the top cover removed. Can you see the shift fork to tell if it is ok and able to slide?
/ Power shift stuck in 2 #5
Is there even a shift fork in PS? I assumed it was like an A/T where the shift lever moves pistons to open/close various paths for hydraulic fluid. To engage/disengage clutch packs.
So repairing the linkage somewhere before those pistons seems to be the next step.
Has anybody torn into a PowerShift?
And I assume the problem here is in the PowerShift portion of the transmission. The range selector part would be a normal geared transmission with forks etc.
/ Power shift stuck in 2 #6
A picture of it.
/ Power shift stuck in 2 #7
Kinda tough following the diagram. Lot of linkage going on there. Hope it's in linkage for you. Easyier and cheaper.
2013 International WorkStar 7400 Crane Truck, VIN # 1HTWGAAR0DJ296617 (A65563)
2013 International...
AR500 Coyote Target (A65640)
AR500 Coyote...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
John Deere 350B Crawler Dozer (A65579)
John Deere 350B...
2016 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCNKNEC1GZ163679 (A65563)
2016 Chevrolet...
