Power shift stuck in 2
/ Power shift stuck in 2 #2
The 186 came with a column shift and floor shift, which do you have?
/ Power shift stuck in 2 #4
Not sure what you can see with the top cover removed. Can you see the shift fork to tell if it is ok and able to slide?
/ Power shift stuck in 2 #5
Is there even a shift fork in PS? I assumed it was like an A/T where the shift lever moves pistons to open/close various paths for hydraulic fluid. To engage/disengage clutch packs.
So repairing the linkage somewhere before those pistons seems to be the next step.
Has anybody torn into a PowerShift?
And I assume the problem here is in the PowerShift portion of the transmission. The range selector part would be a normal geared transmission with forks etc.
/ Power shift stuck in 2 #6
A picture of it.
/ Power shift stuck in 2 #7
Kinda tough following the diagram. Lot of linkage going on there. Hope it's in linkage for you. Easyier and cheaper.
36in AIM Bucket w/ Teeth Excavator Attachment (A64194)
36in AIM Bucket w/...
213088 (A64276)
213088 (A64276)
1998 Mack DM690SX Chassis Truck  (A62679)
1998 Mack DM690SX...
2020 International HX620 Quint Dump (A62613)
2020 International...
Wolverine SBM-12-72W Skid Steer Sickle Bar Mower  (A62679)
Wolverine...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
