Power port question
/ Power port question #11
I guess my point is, if you do stick with 3/8ths hose into a SAE10 opening, even with the restriction inside do you really think it is an area for concern with that hose size? My setup is a little different from your in that I'm definetely running 1/2 hose into those ports but I think I can do it with 45s instead of 90s which I think are less restrictive. In any event I'm plan on using the non restricted openings except as a last resort. I'm still short one bulkhead fitting from Disc. Hose; you must have depleted the market.
It wasn't me hording the bulkhead fittings. I haven't ordered mine yet. I was giving my local guy the chance but he didn't have the JIC-NPT fittings I wanted so I still do need to order some.
I think I will measure for hoses to replumb the whole thing using 1/2" versus just adding on with 3/8" and see what the price difference is. I also measured things and I can run the input hose around the back of the valve so I can easily use the side port if I want.
2016 Komatsu HM400-5 (A60352)
2016 Komatsu...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
429983 (A61165)
429983 (A61165)
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
